Paint Spraying - Printable Version
+--- Thread: Paint Spraying (/showthread.php?tid=8482)
Pages: 1 2 3
RE: Paint Spraying - JohnD - 30-03-2023
I have sprayed in the past, useing two pack, landed myself with a trip to hospital with isocyanate poisoning and a week jaundice making me look like Homer Simpson!! The car turned out well tho, and still looks good 15 years on!
A very good quality mask is a requirement regardless of the paint type.
I have also used Brushing Coach paint from Craftmaster, and if you take your time and prep well, the finish is just as good as a spray [you can also spray it]
RE: Paint Spraying - Denis Sweeney - 30-03-2023
Second that John
RE: Paint Spraying - Ivor Hawkins - 30-03-2023
I’ll second what Stuart has said regarding two pack, I rig up a rudimentary extraction system, but most importantly, use an air fed respirator, together with the correct filters.
However, you need a hefty compressor to supply the respirator and a professional spray gun.
RE: Paint Spraying - Howard Wright - 30-03-2023
(30-03-2023, 12:24 PM)Ivor Hawkins Wrote: I’ll second what Stuart has said regarding two pack, I rig up a rudimentary extraction system, but most importantly, use an air fed respirator, together with the correct filters.
My paint supplier would not sell me two pack paint unless I confirmed that I had an air fed mask!
That’s fair enough, though I do sneak out for a trundle on my Velocette without a helmet, just to relive the old days when I didn’t have to wear one...does that make me a rebel without a cause?
RE: Paint Spraying - Reckless Rat - 30-03-2023
Just remember, Ivor... the are old bikers and there are brave bikers but there aren't many old, brave bikers.
RE: Paint Spraying - Ray White - 30-03-2023
Something which has so far been omitted is humidity. I rely on a hygrometer. This cheap devise is useful because if you apply paint when there is more than 50% humidity there is a risk of micro blisters that will spoil your paint a few weeks later.
Another thing to remember is that no matter what size your compressor, the air that reaches the gun must be dry. Air as it comes out of the compressor is hot and wet so a good coalescing filter is essential as it will not only remove vapour but also oil aerosols and other micro contaminants.
Hope this helps.
RE: Paint Spraying - andrew34ruby - 30-03-2023
(30-03-2023, 08:39 PM)Ray White Wrote: Something which has so far been omitted is humidity.  I rely on a hygrometer.  This cheap devise is useful because if you apply paint when there is more than 50% humidity there is a risk of micro blisters that will spoil your paint a few weeks later.
Hope this helps.
50% humidity is very low. I've sprayed cellulose in winter foggy conditions and never had micro blisters. Also never had a coalescing filter.
No doubt drier is better, but I've never had those problems.
RE: Paint Spraying - Ray White - 04-04-2023
37% humidity today and no wind.  Ideal spraying weather.
Just saying. Wink
