head bolt torque and block - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: head bolt torque and block (/showthread.php?tid=7900) |
RE: head bolt torque and block - Henry Harris - 12-08-2022 Austin Service Journal, January, 1939 RE: head bolt torque and block - Ruairidh Dunford - 12-08-2022 In practical terms, following this will result in snapped or stretched fasteners, in my experience. 3/8 fastenings can better cope with 30ftlbs and I suspect this directive is an error, unfortunately. You pays your money and you takes your chance. RE: head bolt torque and block - Ruairidh Dunford - 12-08-2022 Woodrow quotes a figure of 50ftlbs for the centre main cap fasteners - when followed - I have found it results in distortion, which locks the crank solid. 35ftlbs appears to be entirely sufficient over repeated applications. RE: head bolt torque and block - Denis Sweeney - 12-08-2022 Many thanks Henry. I wonder what the failure rate was back in the day, I guess as long as the material of the studs is maintained within its elastic limit, repetitive applications should not be an issue……… However there are too many unknowns particularly with the modern materials being used on the studs and so think discretion is the order of the day, I will be restricting the torque settings in future Many thanks for the responses been interesting RE: head bolt torque and block - Charles P - 12-08-2022 (12-08-2022, 01:55 PM)Denis Sweeney Wrote: Many thanks Henry. I guess most garages didn't possess a torque wrench so the calibrated wrist approach outlined earlier probably saved many pulled studs Charles RE: head bolt torque and block - Steve kay - 12-08-2022 I have just checked my 2CV hand book. There is not an erratum slip indicating “ The firing order should read….”: RE: head bolt torque and block - Ruairidh Dunford - 12-08-2022 Tremendous engine, Steve. Simplicity in action, fires both plugs, every stroke - is that correct? RE: head bolt torque and block - Alan - 12-08-2022 It is. RE: head bolt torque and block - Ruairidh Dunford - 12-08-2022 I shall now check this with several sources. RE: head bolt torque and block - Alan - 12-08-2022 Don’t you believe me? |
