Warning [2] Undefined property: MyLanguage::$archive_pages - Line: 2 - File: printthread.php(287) : eval()'d code PHP 8.1.29 (Linux)
Re-babbiting big end bearings - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Re-babbiting big end bearings (/showthread.php?tid=729) |
RE: Re-babbiting big end bearings - Ian Williams - 30-01-2018 These sketches come from Colin Reed, and depict the design of a jig he used when metalling rods, the idea is to make the jig quick release without the need to struggle with extremely hot nuts and bolts. The Rod and cap are metalled separately and Colin tells me the process was quite efficient and reduced the need to let the jig cool and then reheat it every time. ![]() ![]() RE: Re-babbiting big end bearings - john williams - 30-01-2018 ![]() (25-01-2018, 08:05 PM)Greig Smith Wrote: Hello Chaps RE: Re-babbiting big end bearings - Ian Williams - 31-01-2018 Another picture from Colin Reed ![]() RE: Re-babbiting big end bearings - Greig Smith - 05-02-2018 Hello Chaps Just a note to say that the jig concept is going forward tomorrow - drawing on all your collective wisdom this jig needs to be able to pour the shell and the side thrust faces in one pour - it also needs to have some sort of a quick release system so that one can swap out the rods and caps relatively quickly to do consecutive pours without loosing heat out of the mould, but more importantly so you don't have to handle a seriously hot mould 8 times in a row.... Will post some pictures of the results, my supremely talented Engineering friend Steven is already working on a basic concept - for some idea of his skill, pop over to the thread on our new Supercharged single seater and have a look at what he has done for us. Now its just to find a bit more Babbitt material as I don't think we have quite enough... Cheers Greig RE: Re-babbiting big end bearings - Ian Williams - 20-04-2019 Our white metalling project has been on the back burner for a while but today Marcus Ling came over and we successfully poured a couple of new big ends. Next job is machine them up and see if we have full depth metal with no inclusions, if that is successful we can get fully underway with production for several club cars. ![]() ![]() RE: Re-babbiting big end bearings - Ruairidh Dunford - 20-04-2019 Can you describe the tinning process you used please Ian? RE: Re-babbiting big end bearings - Ian Williams - 20-04-2019 This is the part still under development Ruairidh, at this stage we are still experimenting, when we cleaned out the old metal from a few rods we had a couple with what appeared to be a perfectly tinned surface so to prove concept we used these. We do have tinning powder and pure tin so with luck Colin Reed will come up and show us how to correctly tin the rods that require this, I will report on that process in due course. RE: Re-babbiting big end bearings - Ruairidh Dunford - 20-04-2019 Thank you. |
