What would you include in the perfect Austin Seven workshop? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: What would you include in the perfect Austin Seven workshop? (/showthread.php?tid=7043) |
RE: What would you include in the perfect Austin Seven workshop? - Austin in the Shed - 06-01-2022 My wife sometimes suggests moving a bed in there. RE: What would you include in the perfect Austin Seven workshop? - Reckless Rat - 06-01-2022 I certainly would like/need/want some sort of lift. Ideally a moveable single post lift that I could use inside and outside but I'm a few beer tokens short (about four thousand). I've already got most of the equipment I need, including the khazi, sink, heating and air-con as well as a couple of patio chairs for pondering moments. A spray booth is a good idea but as I don't do much painting I just use a roll of polythene sheeting and some roof laths (2x1") to fabricate a sealed box when the need occurs. Attic space is handy. I have 32m² plus a mezzanine. A blank cheque to go mad buying "snap on" garage tools and equipment would be nice, coupled with a win on the lottery. RE: What would you include in the perfect Austin Seven workshop? - Tony Griffiths - 06-01-2022 I suppose the list might be almost endless but as a start I'd go for a heated and insulated workshop minimum 12m x 12m with 1000+ lux shadowless indirect lighting, high enough to have a mezzanine floor, a 4-post or similar lift and shelving all round to take masses of labelled plastic storage boxes to keep everything in order. 3-phase electric supply with multiple outlets Sink and hot water supply Carpeted floor? Epoxy floor? Rubber tiled floor? Failing a lift, a pit. Rails down the sides carrying a cross beam with an electric hoist Strong workbench with a high-quality, swivelling and rotating vice, cupboard and drawer storage and, of course, all the spanners and other tools. A second steel-topped mobile workbench with fitted tool storage Lathe with a spindle bore of 1.25 inches minimum http://www.lathes.co.uk/faq/page2.html; Vertical miller with a power-feed table (this would double as a co-ordinate drill) http://www.lathes.co.uk/faq/page3.html. A small, high-speed 10,000 – 20,000 r.p.m. precision drill http://www.lathes.co.uk/faq/page20.html Multi-speed metal and wood-cutting bandsaw Toggle press - or hydraulic Welding equipment. A large propane bottle and torch. Cleaning bath with pumped supply. 3-litre ultrasonic cleaning tank Hydrovane compressor and bead-blasting cabinet. Wall-mounted hose reel Powerful vacuum cleaner Bisley-type small-drawer storage cabinets packed with every BSF, Whitworth and BA fastening known to man ..etc! RE: What would you include in the perfect Austin Seven workshop? - Stuart Joseph - 06-01-2022 Headroom so I can get the beasties up to minimise bending ?? RE: What would you include in the perfect Austin Seven workshop? - Stuart Giles - 06-01-2022 Have quite a lot of equipment here already, but workshop and garage space is at a serious premium. Going into total pipe dream mode, I would have a 200 sq m machining workshop, another 200 sq m for fabrication and 300 sq m for garaging. I would add a 2 post lift to augment my existing four post lift in the garage and would add a big horizontal borer and a swivel table mill (Maho/Deckel style) to do the stuff my Bridgeport struggles with. Probably would get a Chunkier grinder than my little Jones & Shipman too. Well, along with the building costs, there goes the lottery jackpot I haven't won yet... RE: What would you include in the perfect Austin Seven workshop? - Dave Wortley - 06-01-2022 I wouldn't bother with all the super workshop equipment. I would like a genie in an old oil lamp who would be able to complete any workshop jobs by magic at my command. I'm missing going to the panto this year. RE: What would you include in the perfect Austin Seven workshop? - John Cornforth - 06-01-2022 A bell that rings when Lunch or Dinner is ready ! (Only in my dreams, that one) Seriously though, Light, Warmth and Space before you start adding tools. RE: What would you include in the perfect Austin Seven workshop? - John Mason - 06-01-2022 I go with the suggestions of a heated workshop. My messing about in the garage finishes once the weather turns to cold and does not start again until the spring. Age and a wife who does not stop going on about catching a death from cold is a big factor in my thinking. John Mason. RE: What would you include in the perfect Austin Seven workshop? - jpsmit - 06-01-2022 A Lagonda? (I'll get my coat) RE: What would you include in the perfect Austin Seven workshop? - stuartu - 06-01-2022 A set of easily operated and efficient car skates. Regards, Stuart Edited to add, John C, be careful what you wish for. I installed an electric bell in my workshop coupled to the house doorbell. It seemed like a good idea at the time. It is quite shrill. While it has its uses, you would be amazed how often it rings at a crucial moment, just when you don't want to be startled. S. |
