1.5/16 Sports Rods - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 1.5/16 Sports Rods (/showthread.php?tid=5328) |
RE: 1.5/16 Sports Rods - Terrytuned - 01-12-2020 Bob the first photo this crank had been raced for 5yrs and it was from a friends car, I was only sent the photo. The 2nd crank about the same age I removed from the broken c/case this photo shows the break before dismantling, both were 1"5.16, I would not advise anyone to race with a 1"5.16 they have a limited life. Terry. RE: 1.5/16 Sports Rods - Bob Culver - 01-12-2020 Thanks terry Fast progressing fatigue cracks are often hard to judge but the photo appears as usual to start from the inside. A failure near the middle of crank could reasonably be expected to start from the outside, hence my curiosity. RE: 1.5/16 Sports Rods - Robert Foreman - 01-12-2020 Hello Gene, the fault is the little ends are drilled underneath on the thrust side leading to wear. If they are more than a couple of tenths of a thou oversize then new oversize pins will be required. Personally I wouldn't use any original sports rods with the advent of beautifully designed and made new ones. |
