Warning [2] Undefined variable $thumblist - Line: 1031 - File: inc/functions_post.php PHP 8.1.31 (Linux)
/printthread.php 207 get_post_attachments
DO YOU RECOGNISE THIS CAR - Printable Version
+--- Thread: DO YOU RECOGNISE THIS CAR (/showthread.php?tid=2223)
Pages: 1 2 3 4
RE: DO YOU RECOGNISE THIS CAR - Tony Press - 14-01-2019
(14-01-2019, 12:13 AM)dickie65 Wrote: Hi,
My Dad had a chummy with a back end like your car in the early sixties,
I have a slide photo of it somewhere and its petrol ration book.
I will have to try and find it.
Lovely ribs on the guards, Lucas style sidelights would look better.
Is that a direct drive starter on the magneto motor?
Nice special.
RE: DO YOU RECOGNISE THIS CAR - Steve kay - 14-01-2019
(13-01-2019, 10:11 PM)Mike Costigan Wrote: Steve, I don't think you need worry about its VSCC classification: with documentation showing a 47xxx chassis number according to the Association Chassis Register I'm sure Paul will have no difficulty in getting the VSCC to accept its 1927 dating.
Phew, that's us lower orders in Champagne class still safe then! I know the VSCC has had some "communication challenges" but the very brave acting President Jenny Lees has publicly adopted a plan to accept all pre-1939 cars, thus Rubies, as well as  Model Y Fords and Standard Flying Nines might be able to compete with the thoroughbreds of the PVT.
RE: DO YOU RECOGNISE THIS CAR - Alan - 14-01-2019
Some of us thoroughbred chummies are looking at the champagne class, too. The clues are easier and a bottle appeals more than another tankard.
RE: DO YOU RECOGNISE THIS CAR - Hedd_Jones - 14-01-2019
Nice special.
The side lights are GE Cup, as is the bulkhead and it seems the wings and stays. The nickle cowl points that way too. It would be a pity to remove what on the face of it looks like  an original feature if we were to assume it started life as a Cup, then as the body deteriorated was made into this.
Can we see some of the underside? The transmission tunnel, the body mounting brackets? and the underside of the rear engine mounts please?
RE: DO YOU RECOGNISE THIS CAR - JonE - 14-01-2019
That is exactly what I was thinking... and there might be a chassis plate visible too on the rear crossmember.
RE: DO YOU RECOGNISE THIS CAR - stuartu - 14-01-2019
Paul, I have sent you a pm
Regards,
Stuart
RE: DO YOU RECOGNISE THIS CAR - Paul Nott - 14-01-2019
Hi All
New photos to cast an eye over, hope I've covered all requests.
Ruairidh carb details as follows.
Carb number C1565
Main jet 2.0
Needle Valve 1.5
Its the first time I have looked at the carb in detail, glad I did.
Float chamber full of black slimy stuff but more importantly throttle not opening fully, due to loose spindle nut.
Investigation found the spindle shaft thread damaged resulting in only able to tighten to finger tightness.
Many thanks for your interest, comments very welcome, up to six months ago I had no experience of Austin Seven's but learning fast!
Hi All
Carb number C1565
Main jet 2.0
Needle Valve 1.5
RE: DO YOU RECOGNISE THIS CAR - Ruairidh Dunford - 14-01-2019
Thank you Paul.
So that's pretty conclusively an ex Cup then!
The carb is a 22 so a bit over-choked perhaps... That one is probably 80/57 jets if it hasn't been changed. There is another identical variant which is a 20 which would be better suited if you can find one...
Thanks for the extra pictures, Paul.
Regards,
Stuart
