Different halfshaft tapers - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Different halfshaft tapers (/showthread.php?tid=1228) |
RE: Different halfshaft tapers - Ruairidh Dunford - 27-05-2018 I understand - good firm that. RE: Different halfshaft tapers - Ralf Pickel - 27-05-2018 Definitely - have used them for other wheels, too. RE: Different halfshaft tapers - John Mason - 27-05-2018 I assume that wheels fitted with washers on the wheel studs have non tapered wheel nuts. Just plain nylock nuts fitted. John Mason RE: Different halfshaft tapers - Steve Jones - 27-05-2018 (27-05-2018, 01:28 PM)John Mason Wrote: I assume that wheels fitted with washers on the wheel studs have non tapered wheel nuts. Just plain nylock nuts fitted. Well, yes and no!! You can use plain washers and plain nylocks. My Trials Car has these and has had for around 20 years. The washers do, over time, take up the shape of the countersink in the wheel slightly. However, much neater are purpose made tapered washers, again with standard nylocks. Like many others, I have these fitted to my Ulster. Steve |
