Protective coating for older/weathered paintwork... - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Protective coating for older/weathered paintwork... (/showthread.php?tid=1113) |
RE: Protective coating for older/weathered paintwork... - Hedd_Jones - 24-04-2018 Ruairidh Ankor wax is a good product, but be aware that it sits on the substrate, it does not penetrate. I use it on the firebox and burnished steel of my traction engine over the winter. Because of this I experienced corrosion under the product on the firebox. I cured this by mixing clean engine oil with it, approx 50/50. It still 'goes off' but it penetrates the metal etc. I am told the similar Ankor D product does penetrate, but I wasn't going to buy 25 of the bloody stuff. Both clean off easily with paraffin/diesel. But are waterproof. I painted the chassis of the Green microplas special I had with this, and it gave an excellent finish to what was a well painted chassis but with minor rust here and there. It dries dark brown. Looks like brown boot polish. And you can put a fair thickness of it on, particularly on horizontal surfaces. Another product I have used a lot is 3in1 spray oil. The lighter parts evaporate, leaving a dry film of rape oil, which is brown, but does give an excellent protection given the thickness. I use it on the burnished steelwork where the steamer is sheeted over, but outside between events. On a rusty or dark car this would be ideal. The film comes off fairly easily with paraffin and a scourer pad if you want. RE: Protective coating for older/weathered paintwork... - Ruairidh Dunford - 27-04-2018 I ordered up some Ankor Wax and it arrived yesterday. I have tried it on a small area of the paint and it works really well, very pleased. Thank you for all the suggestions, I have noted them for future reference. |
