Broken Crankshaft - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Broken Crankshaft (/showthread.php?tid=9297) Pages:
1
2
RE: Broken Crankshaft - Nick Turley - 18-04-2024 If you are replacing the crank and all the attendant work and cost. Then my strong recommendation is fit a Phoenix 1 1/8. It will not break. You will keep the dynamics of the mag engine which the thicker crank spoils. However I would definitely get the assembly dynamically balanced because although pre balanced I have found they all need doing again. Its a fit and forget solution. |
