Warning [2] Undefined property: MyLanguage::$archive_pages - Line: 2 - File: printthread.php(287) : eval()'d code PHP 8.1.29 (Linux)
Screw thread on Vacuum wiper - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Screw thread on Vacuum wiper (/showthread.php?tid=9014) |
RE: Screw thread on Vacuum wiper - Dave Mann - 04-12-2023 Neatsfoot oil whatever that is. RE: Screw thread on Vacuum wiper - David Stepney - 04-12-2023 (04-12-2023, 10:41 AM)Dave Mann Wrote: Neatsfoot oil whatever that is. Available from any sadlers or horse tack shop under the trade name Flexalan. RE: Screw thread on Vacuum wiper - Ivor Hawkins - 04-12-2023 Yes, I was told neatsfoot oil was the right stuff, but couldn’t find any on my shelf in the workshop! RE: Screw thread on Vacuum wiper - Colin Wilks - 04-12-2023 When renewing the leather gaiters that surround the swivel hubs on my ex military Land Rover lightweight I impregnated them with copious amounts of vaseline, which made them pliable, water proof and slippery, which sounds like the spec of what you are hoping to achieve. A Merry Christmas to all Box Saloon owners - Tony Griffiths - 05-12-2023 A Merry Christmas to all Box Saloon owners - warm and cosy in the winter weather. RE: Screw thread on Vacuum wiper - Steve Bryant - 06-12-2023 I've obtained a small bottle of Neatsfoot oil to treat the leather cups with. The question is how much to use and where to apply it ? Directions for use welcomed. Stephen RE: Screw thread on Vacuum wiper - David Stepney - 06-12-2023 Put some in a saucer and soak the leather seals in it overnight. Wipe off the excess and fit the seals. RE: Screw thread on Vacuum wiper - Steve Bryant - 10-12-2023 A thought occurred to me when restoring this vacuum wiper motor. Why not make a vacuum tank that is plumbed into the vacuum tube between the engine and the wiper ? Perhaps a one- way valve on the suction side to maintain the vacuum. What are your thoughts or experiences? Cheers, Stephen RE: Screw thread on Vacuum wiper - Henry Harris - 10-12-2023 (10-12-2023, 04:01 AM)Steve Bryant Wrote: A thought occurred to me when restoring this vacuum wiper motor. Why not make a vacuum tank that is plumbed into the vacuum tube between the engine and the wiper ? Perhaps a one- way valve on the suction side to maintain the vacuum. As fitted to 1950's side-valve Fords. RE: Screw thread on Vacuum wiper - Chris KC - 10-12-2023 (10-12-2023, 04:01 AM)Steve Bryant Wrote: A thought occurred to me when restoring this vacuum wiper motor. Why not make a vacuum tank that is plumbed into the vacuum tube between the engine and the wiper ? Perhaps a one- way valve on the suction side to maintain the vacuum. Steve, I've spent most of my career in brake systems and - as I'm sure you realise - that's how brake vacuum servos are done. I guess the main issue would be where to put it. A simple plastic NRV on the engine side should suffice to retain vacuum in the reservoir - assuming everything else seals adequately. From a "design" side the thing you'd have to figure out is how big is enough? I have no idea how much vacuum is 'consumed' by the wiper. You could potentially end up in a dead spot where the vacuum in the tank is quickly exhausted and the suck from the engine is insufficient to evacuate the tank back to a level where the wipers work properly (maybe - just thinking out loud). Another possibility - for those who are hell-bent on making it work and perhaps less concerned about originality - would be a small electric vacuum pump. That could probably be installed out of sight somewhere and should guarantee a steady 'suck'. |
