Main gears - Printable Version
+--- Thread: Main gears (/showthread.php?tid=8517)
Pages: 1 2
RE: Main gears - Peter Naulls - 13-04-2023
Check the mesh of the dynamo gear too. This can make horrible noises if too slack.
RE: Main gears - Reckless Rat - 13-04-2023
Before you do any more stripping and/or investigation, perhaps it might be a good idea to let someone with good A7 knowledge see and hear the car.
RE: Main gears - Ivor Hawkins - 13-04-2023
I concur with Bruce, someone with A7 knowledge should listen to your motor...I have an engineer’s stethoscope (motor mechanics used to use a long screwdriver) and it really does isolate where the noise is coming from and it may well be something very easily rectified without having to whip the motor out.
RE: Main gears - Hugh Barnes - 13-04-2023
Tiger - are you a member of your local Austin 7 Club? If not, I would recommend it as your first action...
I see the Pre War A7 Club have a Staffordshite/Shropshire group... https://a7ca.org/member-clubs/club-meetings-map/
RE: Main gears - Nick Turley - 13-04-2023
I agree with Hugh.
Your best way forward is to join a club you will find experienced help near you.
It's a no brainer.
Mistakes can be expensive and frustrating.
