4 speed remote gear change lever - Printable Version
+--- Thread: 4 speed remote gear change lever (/showthread.php?tid=8321)
Pages: 1 2
RE: 4 speed remote gear change lever - Oxford Jack - 05-02-2023
(02-02-2023, 06:17 PM)Nick Lettington Wrote: Ian Williams posted a beautifully made example similar to this made from a gearbox top married to a steering column. Well worth searching for on the forum.
Steve Hodgson made me a fantastic replica of the Cambridge system (also supplied by Dante and Speedex and probably others)
I have made a search for Ian's post, without success, anyone know where it might be hiding please?
Is it just me or is the search function not very good?
RE: 4 speed remote gear change lever - squeak - 05-02-2023
you may have success here
https://www.austinsevenfriends.co.uk/forum/showthread.php?tid=4292&page=2&highlight=joss
and here
https://www.austinsevenfriends.co.uk/forum/showthread.php?tid=3949&highlight=joss
RE: 4 speed remote gear change lever - Oxford Jack - 06-02-2023
Thank you Squeak, I am much obliged. While the Joss/Ian remote is very similar to the one I saw, it has sophistication in its simplicity, the pivot being an example, brilliant.
Also a fine example of the use of Lumiweld, which has had its detractors here at countless car and tool shows.
I shall retreat to the workshop and contemplate my scrap bin............I am going now and may be some time!
RE: 4 speed remote gear change lever - Ian Williams - 06-02-2023
Hi Jack, sorry I had not responded and thank you Squeak for the links. Jack FYI the Aluminium component of this remote was gas welded, it was not brazed with Lumiweld.
RE: 4 speed remote gear change lever - Oxford Jack - 07-02-2023
Hi Ian,
Thank you for the correction, I was almost ready to set aside my scepticism and believe in the magic of Lumiweld after all! Whatever it is superlative ali welding and a lovely overall job. Despite the originators lack of a lathe, I suspect it is beyond my skill set and ability level.
