handbrake lever - Printable Version
+--- Thread: handbrake lever (/showthread.php?tid=8123)
Pages: 1 2
RE: handbrake lever - Howard Wright - 28-10-2022
Hi Vancevr
Look what has just come up on UK eBay.
https://www.ebay.co.uk/itm/385197183332?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=lzeknjnjsim&sssrc=2349624&ssuid=RnbMnEf6R8m&var=&widget_ver=artemis&media=COPY
It is just the adjuster but the second picture shows how it fits in the adjuster.
RE: handbrake lever - Ian Williams - 28-10-2022
This is Tony Betts who will probably be able to help you with all the bits that you need!
RE: handbrake lever - Vancevr - 29-10-2022
I already talked to tony and he was unable to find the parts I was looking for
RE: handbrake lever - Ian Williams - 29-10-2022
I can supply the threaded brass boss that is attached to the bracket with three rivets if that helps you.
RE: handbrake lever - Vancevr - 30-10-2022
Thanks to the many helpful people I think i will take a crack at making them myself. If that doesnt work out I know where to find you
