C35M dynamo disassembly problem - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: C35M dynamo disassembly problem (/showthread.php?tid=7725) Pages:
1
2
RE: C35M dynamo disassembly problem - JonE - 12-07-2022 as I said, I don't think it's been opened before and doubt it's been in use for long. Yes, of course I can swap out the middle bit, but it's only a thread.... isn't that being a bit defeatist, Howard? But I also take your point...! RE: C35M dynamo disassembly problem - Robert Foreman - 12-07-2022 What is the diameter of the plain portion of the knackered thread measured with a micrometer? RE: C35M dynamo disassembly problem - john williams - 14-07-2022 Try and run the dynamo as a "motor". Short the "F" and "D" together. Connect these two shorted terminals to Positive on a good 6volt battery, dynamo body connected to "Negative" If the dynamo is servicable, it will run as a motor. RE: C35M dynamo disassembly problem - JonE - 15-07-2022 Robert - the stump is 0.4 of an inch, but looking at another 35M it also looks shorter now than an original. So presumably its going to end up as a 3/8, the same as the other end? But that would entail it being put on a lathe in the first place....? John - I wanted to look inside before considering anything else i.e. the condition of the bearing. I may just use the dynamo case and swap the middle out. |
