NKG sparkplug - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: NKG sparkplug (/showthread.php?tid=7355) Pages:
1
2
RE: NKG sparkplug - Alan - 02-04-2022 Do they sell them in boxes of ten in the States too? I never understood that. RE: NKG sparkplug - Charles P - 02-04-2022 (02-04-2022, 12:57 PM)Alan Wrote: Do they sell them in boxes of ten in the States too? I never understood that. Yup They don't suit 2 Volvos so maybe ten outboards? C RE: NKG sparkplug - Alan - 02-04-2022 That’ll be a Chevy V8 and a Harley, then. RE: NKG sparkplug - Ivor Hawkins - 02-04-2022 I’m running on NGKs at the moment, in fact just come back from a blast in the box and it seems to b3 buzzing along nicely, nevertheless, I ordered some Champion D21s this morning, so I’ll see if the old banger runs any better and will report back. RE: NKG sparkplug - Charles P - 02-04-2022 Aside from the slight intolerance to suboptimal mixtures with the more modern versions I've never had a problem with NGKs. I've tried Champions in various grades and compared them to A6, A7 and A8 NGKs and found no difference in performance. C RE: NKG sparkplug - Duncan Grimmond - 02-04-2022 I have had "never touch them" advice regarding Bosch, NGK, Champion and other makes and I've never had any trouble with any specific make or engine. I use Bosch Platinum in the BMW engines I have, I had Champion in the last Austin 7 and the BSA Trike has NGK. I usually change the plugs at around 6000 miles as a matter of course, a little extravagant perhaps. They all seem to start first kick and run well enough IMHO and if they don't I assume it's operator malfunction unless there are other symptoms. (Oops,I shouldn't have said that should I...) RE: NKG sparkplug - Tony Press - 03-04-2022 Check carefully: How to identify fake spark plugs | NGK spark plugs (ngkntk.com) RE: NKG sparkplug - Duncan Grimmond - 03-04-2022 Having read that article I will check... RE: NKG sparkplug - Ian Williams - 03-04-2022 Once you have the correct grade plug and correct mixture I have found no difference in performance between any of the brands. I in actual fact use a lot of NOS Lodge and KLG plugs in my cars simply because I like the appearance of more period looking plugs, and I have been fortunate enough to bulk purchase a few, but that is of little relevance. My original comment was to raise awareness that NGK plugs are not particularly tolerant of less that ideal combustion environments, I do find that if you are going to have an NGK plug go down it will happen quite quickly after replacing them, once they have a fine layer of light brown/grey soot on them they appear to be reasonably reliable. |
