Dixi Winter - Printable Version
+--- Thread: Dixi Winter (/showthread.php?tid=7158)
Pages: 1 2 3 4
RE: Dixi Winter - Mike Costigan - 08-02-2022
I believe the 'twos' and 'fours' indicated the number of inches below the knee - you could also get plus sixes and plus eights!
RE: Dixi Winter - Malcolm Parker - 08-02-2022
Are  kilts similarly graded?
RE: Dixi Winter - Reckless Rat - 08-02-2022
No, if your kilt is properly fitted then it should just touch the ground when you kneel down.
RE: Dixi Winter - Bob Culver - 08-02-2022
Can anyone provide a pic of ifs?
How was track rod sorted?
Maybe if of best German steel a 12mm? kingpin sufficed.
For any youngsters the camera case would not be for a Leica, the camera which championed 35mm, but for a folding camera with bellows which opens out to provde the long focal length for a relatively large film
This is the best I can offer; basically a swing-axle design retaining the transverse spring:
.jpg   1931 BMW DA4 (2).jpg (Size: 196.28 KB / Downloads: 219)
RE: Dixi Winter - Bob Culver - 09-02-2022
Thanks Mike
It almost looks like the spring and axle and stub axle assy form a parallelogram rather than a simple swing axle. Almost looks like a single piece track rod, not ideal but not impossible. Hopefully the roll centre wherver it is does not further worsen roll cf whrever it is normally.. Brake lever looks reversed...
RE: Dixi Winter - Duncan Grimmond - 09-02-2022
A bit like this one I'd expect. It would be so good to have the clockwork trigger to fit to the remote operating push...
RE: Dixi Winter - Mike Costigan - 10-02-2022
(08-02-2022, 11:17 AM)Reckless Rat Wrote: No, if your kilt is properly fitted then it should just touch the ground when you kneel down.
Are you sure?
.jpg   kilt.jpg (Size: 104.27 KB / Downloads: 116)
RE: Dixi Winter - Reckless Rat - 10-02-2022
If you want to find out a Scotsman's name, put your hand up under his kilt. If he's got a Quarterpounder then his name is MacDonald....
RE: Dixi Winter - Ivor Hawkins - 10-02-2022
How many budgies can you get up a Scotsman’s kilt?
Depends how long the perch is...
