block skimming - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: block skimming (/showthread.php?tid=6669) Pages:
1
2
RE: block skimming - Tony Betts - 22-09-2021 sorry flywheel. but the block can warp, just the same as the head. personally id do the head and block together, get the best seal on the gasket. tony RE: block skimming - Tony Press - 22-09-2021 As mentioned above- do not fit a '37' head to an 1 1/8" crank engine. More than pinking happens RE: block skimming - Dave Mann - 23-09-2021 Cotterell Facebook page is interesting, it's a while since I've seen a Delapena hone in use. RE: block skimming - John Mason - 23-09-2021 Getting back to your original enquiry I always use Mansfield engines in Mansfield. They are on the internet. John Mason. RE: block skimming - flywheel1935 - 24-09-2021 (22-09-2021, 09:12 PM)Tony Betts Wrote: sorry flywheel.Hi Tony, meant to say just skim head, and try it first before total strip of block off crankcase ? RE: block skimming - Austin in the Shed - 24-09-2021 Getting all the studs out of the block without any breaking will be a mission too. Plenty of heat,hammering and plus gas. And a good stud removal tool. RE: block skimming - Chris Garner - 24-09-2021 ... and the best stud removal tool in my opinion is the Bluepoint one as illustrated. Expensive but worth the money. RE: block skimming - Dave Mann - 25-09-2021 I find a week in Deox C makes stud removal much easier, just protect any machined surfaces with a liberal coating of grease. |
