Grade of Steel for Spring Shackle Pin - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Grade of Steel for Spring Shackle Pin (/showthread.php?tid=6661) Pages:
1
2
RE: Grade of Steel for Spring Shackle Pin - Bob Culver - 22-09-2021 Unfortunately the shoulder is too small to enable recovery by grinding. The wear encountered on some cars was remarkable. I have seen them worn into the steel of the axle. Despite the traditions of the time many owners never greased cars, or troubled to unblock drillings (The old greases like Castrol CL dried; formed a useful crust but more prone to blockage than modern). Uses of are limited although I have used for levering RE: Grade of Steel for Spring Shackle Pin - jr2766 - 25-09-2021 The choice of steel grade for this application is definitely EN24 or 4340. The steel is inexpensive and easy to machine. The pins should be ground after heat treatment to give long service life. Harden and temper back to 48 to 50HRc. Similar comment for king pins Jim Runciman RE: Grade of Steel for Spring Shackle Pin - Bob Culver - 25-09-2021 Presumably anyone making would use separate endplates or drill the old and use double ended pins. i understand for kingpin safety some use hard chrome plated HT rod as for hydrauics. That eliminates the heat treatment ritual |
