Stops very well with lots of charm.... - Printable Version
+--- Thread: Stops very well with lots of charm.... (/showthread.php?tid=5842)
Pages: 1 2
RE: Stops very well with lots of charm.... - Hedd_Jones - 24-03-2021
Yup. This is the Opal of the Jewell Range launched in August 1934
RE: Stops very well with lots of charm.... - Reckless Rat - 24-03-2021
It says it's a PD tourer in the ad blurb, which it looks like. An Opal is an open topped two seat version of the Ruby saloon isn't it? (ie with a Ruby style bonnet and rad cowl)
Or have I missed something?
RE: Stops very well with lots of charm.... - Robin Oldfield - 24-03-2021
The Car & Classic website says 1934 but, yes, it could still be an Opal which for some time retained the Chrome rad etc but with some Ruby-type parts such as automatic advance/retard so the steering wheel is probably correct.
RE: Stops very well with lots of charm.... - Mike Costigan - 24-03-2021
We've covered this before, Bruce. The Opal was the chrome-rad APD 2-seater introduced in late 1934 with Ruby steering column and wheel but still on the high frame. The 'Ruby'-fronted low-chassis APE 2-seater came in mid-1935 and was officially just called '2-seater'! Needless to say, we call all of them Opals.
Assuming it is the original number and I fully accept there is no paperwork, the CPG registration was issued from March 1935.
Its not unusual to see a car made late in one year to be registered in the first part of the following year. But I think its pretty obvious its a APD Opal.
It may also be worth commenting that in the 1920's and 30's an open top car was the base spec, the 2 seater 'the' poverty model.
Hence why the chrome rad continued on the 2 seater (and the van) with the updating the higher spec models in August 1934 - the Ruby, the Pearl and the 4 seat Tourer.
Quite the opposite is true now. With the saloons being considered less desirable than any of the open cars.
RE: Stops very well with lots of charm.... - Tony Betts - 24-03-2021
top comes down, price goes up.
RE: Stops very well with lots of charm.... - Tony Griffiths - 24-03-2021
Mike is correct of course and, having gained First in Anorakory, was the first to comb through the literature to prove it. After it was fitted with a Ruby cowl, the Opal was indeed henceforth listed as the "Two-Seater" - but one wonders why? Did Austin want to separate it from the 'gemstone range' when it was just the base model?
Applies in other situations, too...
Thanks for the "heads-up". Thank goodness I have a saloon, I don't think I could live with all the confusion if I had a drop-top!
RE: Stops very well with lots of charm.... - Parazine - 25-03-2021
(24-03-2021, 08:14 PM)Reckless Rat Wrote: Thanks for the "heads-up". Thank goodness I have a saloon, I don't think I could live with all the confusion if I had a drop-top!
No Confusion with a Chummy! Unless it's an AB Pramhood, AC Pramhood, early AD, later AD, late AD, early AE.......
