Oil holes in lay gear assembly - Printable Version
+--- Thread: Oil holes in lay gear assembly (/showthread.php?tid=5518)
Pages: 1 2
RE: Oil holes in lay gear assembly - Peter Arnold - 16-01-2021
Thanks Chris I made a tool just like that and it worked like a dream. The bicycle shop had balls the right size so I put a new set in. The little tool for removing the bush from the layshaft worked well and I put a shim behind the bush and now have an end float of .004”.
Thank you for your comments Parazine and Bob.
Cheers.
