Grease gun recommendation - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Grease gun recommendation (/showthread.php?tid=5315) Pages:
1
2
RE: Grease gun recommendation - Malcolm Parker - 27-11-2020 I have a Wanner type, I always pull the plunger back and secure it with the chain when not in use. It still leaks a bit but I think that is due to temperature changes. It pays to keep an old rag next to the grease gun. RE: Grease gun recommendation - John Mason - 27-11-2020 I have had mine for years don’t know the make. I bought a flexible hose from Amazon (Not a sponser) and found it far better to get into awkward places. I did have to put my old end on however as it fits and grips the nipples better. John Mason RE: Grease gun recommendation - David Witton - 27-11-2020 (27-11-2020, 10:42 AM)John Mason Wrote: .....I did have to put my old end on however as it fits and grips the nipples better.I say, steady on old chap! RE: Grease gun recommendation - Nick Salmon - 27-11-2020 I was taught that if the nipple does not quite fit snugly enough into the grease gun nozzle, you put a stocking/tight (just a piece, not the whole thing!) over it first. Probably wise to remove the lady from the stocking/tight first. RE: Grease gun recommendation - Steve Jones - 27-11-2020 I've never, really, got on too well with any grease gun but I've used a Wanner for a long time and that's about the best. I do find that mine air locks a lot for some reason and can be a pain to clear. Like others, I release the tension on the spring by pulling the plunger back when not in use. Steve RE: Grease gun recommendation - Chris Garner - 27-11-2020 Years ago I lent my Wanner out to a neighbour. He returned it saying he'd refilled it with grease. However he'd just taken the cap off and put the grease the wrong side of the piston! RE: Grease gun recommendation - Ian McGowan - 27-11-2020 (27-11-2020, 09:48 AM)Malcolm Parker Wrote: I have a Wanner type, I always pull the plunger back and secure it with the chain when not in use. It still leaks a bit but I think that is due to temperature changes. It pays to keep an old rag next to the grease gun. +1 Ian Mc. RE: Grease gun recommendation - Peter Naulls - 27-11-2020 Thanks everyone. I shall pull the plunger back on the one I have and see what happens. Failing that I'll ask Father Christmas for a Wanner. RE: Grease gun recommendation - Colin Wilks - 10-06-2022 Some time ago I took a punt on a Wanner grease gun on eBay. Used it for the first time this week and it is a revelation. Air bleed valve and back pressure relief valve that work perfectly, and a nozzle that swivels, locks on and releases without drama. There are several on eBay this evening. Highly recommended. RE: Grease gun recommendation - Peter Naulls - 11-06-2022 Thanks Colin. I've been storing mine with the plunger pulled back and it has cured the leakiness completely. Much less messy. |
