Dimensions SWB Ulster - Printable Version
+--- Thread: Dimensions SWB Ulster (/showthread.php?tid=524)
Pages: 1 2
RE: Dimensions SWB Ulster - Charles P - 03-12-2017
I learnt the hard way to cut the side tubes, make a sleeve, bolt the diff, half shafts and hubs together and tack it together using the high precision "weld where it touches" approach.
RE: Dimensions SWB Ulster - Steve Jones - 03-12-2017
(03-12-2017, 12:52 PM)Charles P Wrote: I learnt the hard way to cut the side tubes, make a sleeve, bolt the diff, half shafts and hubs together and tack it together using  the high precision "weld where it touches" approach.
Me too Charles. I also offer up the tacked up axle to the springs previously fitted into the chassis frame to make sure all the eyes line up before making things permanent.
