Spade end plug leads - Printable Version
+--- Thread: Spade end plug leads (/showthread.php?tid=4876)
Pages: 1 2
RE: Spade end plug leads - Steve Jones - 30-08-2020
I finish these with heat shrink as well. As well as insulating, it makes the whole thing more robust and less prone to failing in the long term through vibration.
RE: Spade end plug leads - Howard Wright - 30-08-2020
Ditto
RE: Spade end plug leads - A G Wood - 31-08-2020
Hmm, after seeing Howard's set up I can see I will have to remove some of the "patina" on my engine...
RE: Spade end plug leads - Howard Wright - 31-08-2020
Don’t
Unless you want to swap it for mine  Smile Smile Smile.
It’s a new build so hopefully it will tone down soon.
RE: Spade end plug leads - bobthompson - 01-09-2020
Love the hoses - where do they come from?
RE: Spade end plug leads - Howard Wright - 01-09-2020
Hi Bob
They are an eBay purchase listed as EPDM wire reinforced hose (32mm).  Sorry can’t seem to copy and paste the listing.  I made the clips myself from 12mm brass strip.
Hope that helps?
Brilliant! Ordered.
Thanks
