thin flat 2nd. files with a cutting edge/side? - Printable Version
+--- Thread: thin flat 2nd. files with a cutting edge/side? (/showthread.php?tid=4636)
Pages: 1 2 3
RE: thin flat 2nd. files with a cutting edge/side? - Derek Sheldon - 07-07-2020
Have you tried searching for RIFFLER FILES on eBay ?
RE: thin flat 2nd. files with a cutting edge/side? - JonE - 08-07-2020
yes, I can see some of those would work too, but in a short un-efficient movement. I'll see what the first purchase brings!
I'm trying to put an egg-crate grille together by hand tool work alone, btw. I can see why not many people make them...
RE: thin flat 2nd. files with a cutting edge/side? - Nick Lettington - 08-07-2020
I would think that the bottom of the hole doesn't need to be flat Jon. With the slats slotted together it won't show.
yes, I realise, but I started to think it might not need any fixing if it's all super tight...!
RE: thin flat 2nd. files with a cutting edge/side? - Colin Wilks - 08-07-2020
Hi Jon
Have you considered putting more than one blade in your hacksaw?
RE: thin flat 2nd. files with a cutting edge/side? - Stuart Joseph - 08-07-2020
Good morning Jon. Apologies if I have missed this in the thread but what you are looking for are 'WARDING' files as used by locksmiths. Not to be confused with Swiss or Needle files which even some of the suppliers do.
Stuart
(08-07-2020, 09:23 AM)Colin Wilks Wrote: Hi Jon
I'll look up Warding, Stuart, thanks.
Colin - how in practice would one do this - tape them together? Or can more fit on? I like the idea!
Hi Jon
Assuming you have a standard 12" hacksaw, just stick 'em on the lugs of the handle and tighten it back up. You may have to squeeze the blades together to start the cut prettily, but once started they will behave themselves. You'll struggle if you're using a junior hacksaw of course. I've never bothered, but I think you can get blades of different thicknesses if needed.
By the bye, I shall be 68 next birthday and Derek Sheldon's "Riffler Files" have entirely passed me by. I'm starting to wonder what else I've missed out on!  Dodgy
RE: thin flat 2nd. files with a cutting edge/side? - Derek Sheldon - 21-07-2020
RE: thin flat 2nd. files with a cutting edge/side? - Bob Culver - 21-07-2020
Not clear exactly what you trying to do but is there any scope for traversing a cutoff disc? Assuming you do not have a slide compound saw, lathe etc can clamp hold the grinder somehow and slide a vice berween woodenor metal guide strips etc
