Stripped Thread - Best Solution? - Printable Version
+--- Thread: Stripped Thread - Best Solution? (/showthread.php?tid=4613)
Pages: 1 2
RE: Stripped Thread - Best Solution? - Ray White - 03-07-2020
In this case I would think 9mm of good thread should be fine with the longer bolt. I would leave it but add a little thread locker.
Ray.
RE: Stripped Thread - Best Solution? - Howard Wright - 03-07-2020
Hi
I’d be cautious about using too strong a thread lock for these bolts.  Unless you’ve transferred the timing marks to the front cam pulley you need to have the starter housing off every time you set the timing. I had some dynamo problems with my RK and the housing was on and off like a yo-yo  Smile
PS On the three early engines I’ve worked on all had these holes drilled and tapped to 3/8”.
RE: Stripped Thread - Best Solution? - Ian McGowan - 03-07-2020
John, I would use longer bolt for now and save helicoil for next time you have the engine out - much easier to do when you can get right over the top of the hole.
   Check the actual thread first though; there has been mention here of BSF but, one of my crankcases has 5/16" BSW at this point.
I definitely would NOT use thread lock on these bolts.
