Warning [2] Undefined property: MyLanguage::$archive_pages - Line: 2 - File: printthread.php(287) : eval()'d code PHP 8.1.29 (Linux)
OIL GAUGE FEED PIPE - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: OIL GAUGE FEED PIPE (/showthread.php?tid=4498) Pages:
1
2
RE: OIL GAUGE FEED PIPE - Dave Wortley - 09-06-2020 The same goes for petrol pipes, silver solder only. You don't want a fractured petrol pipe nor a fractured oil pipe. Cheers, Dave. RE: OIL GAUGE FEED PIPE - Duncan Grimmond - 09-06-2020 Having dismantled a few petrol tanks to re-use original fittings such as breather, filler neck, pick up pipe etc. I can report that in every case these were all soft soldered. Further, every oil pressure feed (including new ones) I've seen has also been soft soldered. RE: OIL GAUGE FEED PIPE - David Stepney - 09-06-2020 I have used soft solder on the occasions that I have had to fit nipples too various pipe work, including both oil and fuel lines. Not had a problem yet. RE: OIL GAUGE FEED PIPE - dickie65 - 09-06-2020 I seem to remember that in the bad old days Solder was not just Solder. There was Plumbers Solder with more lead and a higher melting point. There was Tinsmiths Solder with more tin in it and a lower melting point. And a few different compostions of the lead tin alloy I have a feeling Antimony was is some solder but can not be sure. I would never use the horrible lead free solder on my car plumbing. The Advantages of Antimony in Solder Alloys Antimony has demonstrated several advantages when used as a doping agent in solder alloys. When used in tin-lead solders in the 0.3% - 0.5 % range, the alloys exhibit better thermal fatigue resistance than alloys that do not contain antimony. I just found the above on the Web. It seems I was paying attention in my metalwork class Got the GCSE to prove it. RE: OIL GAUGE FEED PIPE - Bob Culver - 09-06-2020 Lead/tin soft solder fatigues rapidly under any cyclic loading and there is a lot of vibration at the oil pipe. Unless the load is spread over a large area (as in long telescoped section), the strength has to come primarily from the mechanical fit RE: OIL GAUGE FEED PIPE - Parazine - 09-06-2020 I have to say, I've soft soldered (with plumbers solder admittedly) fuel and oil pipes for the last 45 years. Not had a problem yet, despite some high mileages, especially in the early days. It's not that I don't have the wherewithal to silver solder the pipes, just hasn't been necessary. I believe the factory soft soldered them in the day...... RE: OIL GAUGE FEED PIPE - Stuart Giles - 09-06-2020 Impossible to say whether the numerous gnarly copper oil and fuel pipes with silver soldered nipples I have come across were installed by the factory, but I've never seen a failure of a joint in one. By comparison, I have seen several soft soldered joints to nipples that have failed, that's why I wouldn't soft solder one of these joints. Each to their own. |
