Autosparks wiring diagram? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Autosparks wiring diagram? (/showthread.php?tid=4425) Pages:
1
2
RE: Autosparks wiring diagram? - Ian McGowan - 27-05-2020 Here is what Autosparks website lists as their AC2 WIRING HARNESS: Austin Seven Ruby Wiring Harness Set [b]Part NO:[/b] AN2c [b]Year:[/b]1935 - 1938 [b]Finish:[/b]Braided Cables with a Braided Outer Covering [b]Chassis NO:[/b] APE-ACA & APD-ARQ Third Brush Control. Dynamo and Starter on R/H Side. Built with Twin Filament Headlamps as standard They state that they do NOT do a wiring diagram for this but that they follow British Standard Wiring Colours which they list on their website here: https://www.autosparks.co.uk/bscc I would imagine that using the diagram here: http://www.da7c.co.uk/technical_torque_articles/Ruby_Wiring_v4%20A4.pdf combined with the BSW colour codes from Autosparks you should be able to progess. RE: Autosparks wiring diagram? - Stuart Giles - 27-05-2020 That Lucas RB108 box isn't an A7 part as posted previously. AFAIK it's made for a 2 brush dynamo, not the 3 brush style that the A7 had from the factory. But as long as it's the 6V version, it should still operate as the cutout that you need if you just use the D (dynamo) E (earth) and A (output to ammeter) don't connect the field terminal as the A7 system controls the field from the ignition switch or panel on the dash. You'll need to add a resistor in the field circuit to get the 'summer half charge' to work. RE: Autosparks wiring diagram? - Caddy1980 - 27-05-2020 Perfect thanks for the help. I think I’ll lay it all out at the weekend to try and work out whats missing. Thanks again Aaron RE: Autosparks wiring diagram? - Jeff Taylor - 28-05-2020 The Lucas Control Box Model RB108 was apparently fitted to tractors, motor cycles and stationary engines - it looks no earlier than 1950's to me. You can find details of it on page 14 in the link below: https://www.traction-owners.co.uk/wp-content/uploads/2017/01/LucasGeneratorOutputControl.pdf RE: Autosparks wiring diagram? - flywheel1935 - 28-05-2020 Note' the Essex wiring diagram shows a Positive Earth ??? My own ARQ Ruby is Negative earth, or was when I bought it 30 years ago, think A7's changed a couple of times during their production ??? |
