CLUTCH TOGGLES QUESTION. - Printable Version
+--- Thread: CLUTCH TOGGLES QUESTION. (/showthread.php?tid=4387)
Pages: 1 2
RE: CLUTCH TOGGLES QUESTION. - Rpm - 21-05-2020
Certainly many ways to consider. The grub screw option sounds good, once tapped.
RPM
RE: CLUTCH TOGGLES QUESTION. - Steve Jones - 21-05-2020
There are many different ways, each with their own supporters. I've used the grub screw method on all my clutches for a lot of years with success. However, whatever method you use, make sure that all the other components in the clutch and its mechanism are in good condition and replace if they aren't. The Austin 7 has a reputation for an 'on - off' clutch. If everything is in good condition and it's set up properly it won't be so.
Thanks, Steve for your reassuring comments,.
Rob
