Damaged or Unservicable parts - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Damaged or Unservicable parts (/showthread.php?tid=4292) Pages:
1
2
RE: Damaged or Unservicable parts - Ian Williams - 02-05-2020 You have a stock of high quality steel and aluminium that can be turned into something else, all you need is imagination, this is the example I referred to entirely made from scrap box materials. RE: Damaged or Unservicable parts - Duncan Grimmond - 02-05-2020 That's probably the nicest remote change I've seen. RE: Damaged or Unservicable parts - Andy Bennett - 03-05-2020 Hi Winston I sent you a PM yesterday. cheers Andy RE: Damaged or Unservicable parts - JonE - 04-05-2020 (02-05-2020, 09:53 PM)Ian Williams Wrote: You have a stock of high quality steel and aluminium that can be turned into something else, all you need is imagination, this is the example I referred to entirely made from scrap box materials.This is very interesting, as seeing it, one can start to see the possibility for doing things yourself. But a lot of us don't have lathes or the ability to weld. I'm starting to investigate what can be done with a plumbers propane torch - could that aluminium weld be done with that? What are the functions at the left hand end and which are the recycled bits which contribute to them please? Is that a spring shackle half way down the gearstick? RE: Damaged or Unservicable parts - Ian Williams - 04-05-2020 Here is another example of things made from scrap, I made this yesterday in less than 2 hours from a broken ruby exhaust manifold. it is to allow a friend to use an SU on his special, it could also be inverted and would allow an SU to be used on a gravity fed car with scuttle tank. IMG_20200504_170921.jpg (Size: 172.21 KB / Downloads: 182) Jon take a look at Joss thread " column remote gear change" for more pictures RE: Damaged or Unservicable parts - Joss - 04-05-2020 Hi Jon, The brass toward the base of the stick is the reverse lock out, you can just make out the spring on its underside (a cut down bulldog type paper clip). The recycled pieces are: 4 speed gearbox lid, steering box case and outer column, 3 speed gate stick, Ford 10 inner column, Ford 10 outer bearing race, Ford gear knob,and a N.Z. rail spanner. The rest being steel off cuts. Ali was gas welded, the rest done with arc (lots of build up and filing). I also have no lathe so tend to view projects as hacksaw and files (many happy hours). Finally, you should be able to glue the ali castings with propane using low temp rods, I believe they are available in the U.K. under the name Lumiweld. hope that answers your questions. cheers Joss |
