Oil Button - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Oil Button (/showthread.php?tid=3862) Pages:
1
2
RE: Oil Button - Hugh Barnes - 06-02-2020 Then it might be your lucky day, Mike!! https://www.carandclassic.co.uk/car/C1165507?fbclid=IwAR0FR0kKtTCiRl2gDUFRBXmNKNeqIPCwzyeRKE_rvg7UJ1JuDuElWOeOluw RE: Oil Button - Mike Costigan - 06-02-2020 Looks like it needs a lot of work! Here it is back in the mid-1970s: 006.800.jpg (Size: 82.54 KB / Downloads: 304) RE: Oil Button - Mark McKibbin - 06-02-2020 Thanks for the answers, from the parts book for a 1927 car I need a button that looks like this one and I will get another patent plate (magneto one smaller) RE: Oil Button - Robert Leigh - 06-02-2020 Here is slightly poor picture of our early'28 layout, with contemporary dash light and underdash lidded cubby holes. I believe the original bits are how yours should be. Robert Leigh RE: Oil Button - Austin in the Shed - 06-02-2020 Measured from my chummy the hole is 8" in from o/s of dash and 4 7/8" up vertically from bottom edge of dash.If you get stuck I could help with a reconditioned round oil button. RE: Oil Button - Tony Press - 07-02-2020 You can also with a bit of fiddling get a Lucas SM3 switchboard to operate a coil ignition engine. RE: Oil Button - Mark McKibbin - 07-02-2020 (06-02-2020, 10:46 PM)Austin in the Shed Wrote: Measured from my chummy the hole is 8" in from o/s of dash and 4 7/8" up vertically from bottom edge of dash.If you get stuck I could help with a reconditioned round oil button. I assume it's centred on the steering column? (07-02-2020, 01:56 AM)Tony Press Wrote: You can also with a bit of fiddling get a Lucas SM3 switchboard to operate a coil ignition engine. I will lookout for an SM3 and give it a shot, I assume the SM3 puts an earth on the maggy to stop whereas the SM5 puts battery on the coil to go. (06-02-2020, 03:50 PM)Robert Leigh Wrote: Here is slightly poor picture of our early'28 layout, with contemporary dash light and underdash lidded cubby holes. I believe the original bits are how yours should be. I like the cubby holes, desperately needed as I don't even have door pockets. RE: Oil Button - AustinWood - 07-02-2020 I suspect your dash board isn't the original, hence no provision for oil button. Andrew Goodfellow of Creative Metalwork made a new one for my 1929 RK fabric saloon. Excellent work and very good value. |
