6V wiring... - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 6V wiring... (/showthread.php?tid=3462) Pages:
1
2
RE: 6V wiring... - Ferg3 - 29-10-2019 What is it called, John......how to find on eBay? Sounds ideal. Thanks! RE: 6V wiring... - Ian McGowan - 29-10-2019 This is the same item from the Green Spark Plug Company. https://www.gsparkplug.com/disconnect-type-battery-terminals-switch-isolator-cut-off-switch-no-fuse-holder.html RE: 6V wiring... - Tony Press - 29-10-2019 I think this excellent green knob (ooh Matron) switch is for a negative earth battery ? An earlier post indicated positive earth ?? Although- shouldn't a 33 Seven be negative earth ??? RE: 6V wiring... - John Mason - 30-10-2019 You can get them in different colours Red I think for positive battery terminal and also done with black knob. John Mason |
