Strange noises from rear end. - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Strange noises from rear end. (/showthread.php?tid=2907) Pages:
1
2
RE: Strange noises from rear end. - Bob Culver - 06-06-2019 Hi Smiley It is only work if something wrong. A s.a can be easily disconnected at the link; if not the problem need proceed no further. Driving without is interesting; the roll can be truly impressive. RE: Strange noises from rear end. - Ian Motley - 07-06-2019 Have you checked the rear hub. Check that the Rear Hub that contains the Bearings is not Cracked where it meets the Shoulder that has the Wheel Studs. RE: Strange noises from rear end. - Smiley - 15-06-2019 Hi Ruairidh, Further to my original thread on this problem, I just thought, I would say that I took your tip and stripped the rear shocker. What did I find? One of the discs had broken completely in two. Aftercleaning and fitting new friction and brass discs the creaking disappeared completely. I still have a slight KNOCK when hitting a pot hole. Any ideas on that one. ? RE: Strange noises from rear end. - John Raeburn - 16-06-2019 Avoid Pot Holes!! RE: Strange noises from rear end. - "Slack Alice" Simon - 16-06-2019 I had creaks and knocking noises until I replaced the worn out spring pins and bushes. RE: Strange noises from rear end. - Howard Wright - 16-06-2019 Hi Also check the torque tube socket (or bracket). If the hollow bolt on the bottom is not tight enough the bracket jumps up and down and make a knocking noise over bumps! Cheers Howard |
