SU 1' OM type damper cap type - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: SU 1' OM type damper cap type (/showthread.php?tid=2719) Pages:
1
2
RE: SU 1' OM type damper cap type - Charles P - 29-04-2019 (29-04-2019, 06:09 PM)stuartu Wrote: ................ I would think the finger from a redundant rubber glove might work. I'm painfully tempted to make an alternative suggestion but have resisted the urge by the sheer force of willpower Charles RE: SU 1' OM type damper cap type - Jeff Taylor - 29-04-2019 "Which just goes to show that you should never throw anything away... Found this in a box of toot from my dad's man tin. No idea what it was!" Worth £16.20p inc. VAT at Burlen's prices Nick ! RE: SU 1' OM type damper cap type - Tony Press - 29-04-2019 Refer the earlier discussion on SU Carburettors . The unvented cap wasn't introduced until post war and all earlier caps were fitted without a fibre washer. The OM had no damper piston. RE: SU 1' OM type damper cap type - Nick Lettington - 29-04-2019 (29-04-2019, 11:08 PM)Charles P Wrote:(29-04-2019, 06:09 PM)stuartu Wrote: ................ I would think the finger from a redundant rubber glove might work. I'm equally painfully tempted to suggest that you must purchase extra small ones Charles if they are the size of a finger on a rubber glove?! Thanks Jeff. Is it worth more if it is original and has patina? RE: SU 1' OM type damper cap type - Robin Gooders - 30-04-2019 Thank you Ian. Robin |
