How to set up an external oil filter on splash fed? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: How to set up an external oil filter on splash fed? (/showthread.php?tid=268) Pages:
1
2
RE: How to set up an external oil filter on splash fed? - Au5t1n7 - 25-09-2017 (25-09-2017, 08:09 AM)Derek Sheldon Wrote: This is a shot of the filter fitted to my Rosengart van . As you can see the oil pressure gauge is taken off of the top of the filter. I am pretty certain that I got the unit from Paul Bonewell. As stated earlier you have to block off the oil chamber . I used the same size tap as the thread in the chamber plug and ran it on in. For the plug itself I turned off the hex on the plug that I removed on other end of the chamber. The original oil pressure outlet will also need enlarging. Thanks Derek. What a cracking set of engines! |
