Chassis number location Mid 1927? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Chassis number location Mid 1927? (/showthread.php?tid=2567) Pages:
1
2
RE: Chassis number location Mid 1927? - Bill Sheehan - 27-03-2019 AllAlloyCup - your chassis & engine numbers were only on the rear cross member because all Pram Hoods were stamped there (as well as the front nearside, forward of the engine foot), but this former was discontinued in late 1926. Hedd, am confident you'll find it stamped on the front left, as I've never seen it anywhere else on a 1927. I recall saying this once before on the Forum but you queried that at the time 'cos you said one of your chasses had a plate on the rear. This was because it had a Gordon England body, whereas I was only talking of standard chasses. No one else had plates attached. Even the numbers on crankcases that came out of Gordon England generally had different numbers to the standard Longbridge jobs. Good Luck with your search. BTW, is your inlet water pipe still holding up? Cheers, Bill in Oz RE: Chassis number location Mid 1927? - AllAlloyCup - 28-03-2019 Hi Bill, David Cochrane confirmed that my car had probably been a Pram Hood Chummy body, but sadly(?) I don’t have the 6” axles Nor a mag engine.( I decided to go for an early coil engine as I know nothing about Magnetos) I knew GE cars had such a makers ( Austin) chassis plate stating that they were the property of the factory( till sold as completed cars) . My understanding was that other “volume” coach builders using chassis bought from Longbridge also had a similar plate? So Swallow, Mulliner etc models may have also had this plate? Can anyone confirm that? Presumably the chassis etc were supplied by Austin on a sale or return basis and coach builders only paid Austin when completed cars were sold. If by some misfortune they went out of business Austin’s could retrieve Their property without going through the administrator or liquidator? Ps I’d love a plate to borrow to make some facsimiles... All the best Bill G RE: Chassis number location Mid 1927? - Bill Sheehan - 28-03-2019 Correction to above & apologies. My mention of Gordon England - it should have read G.E. Brooklands - not sure about the crankcases in Cups or their saloons. Cheers, Bill in Oz RE: Chassis number location Mid 1927? - Hedd_Jones - 28-03-2019 Bill. The side water branch is doing sterling service on this. Just fetched daughter No1 from school. Many thanks ![]() RE: Chassis number location Mid 1927? - JonE - 28-03-2019 (27-03-2019, 11:03 PM)Hedd_Jones Wrote: Jon, also for reference. A aluminium plate on the rear crossmember is also a possibility for chassis number location not for factory cars though... buy it if its got a plate!! Have you found it yet? We're all waiting patiently... RE: Chassis number location Mid 1927? - Hedd_Jones - 28-03-2019 Nope!. Not in either location. Not buying it The factory fitted those plates...... RE: Chassis number location Mid 1927? - JonE - 28-03-2019 Could it be one of those 1929s then with no stamp?! Any turn ups on the chassis rails? pic of one of these 'ere plates?? RE: Chassis number location Mid 1927? - Hedd_Jones - 28-03-2019 this one has holes under where the spring mounts, tubular strengtheners and bolted extensions. Deffo not 1929! |
