Rust pitting on flywheel - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Rust pitting on flywheel (/showthread.php?tid=2532) Pages:
1
2
RE: Rust pitting on flywheel - Chris KC - 21-03-2019 Unless it's been done before, then you only need hack the ring off and perhaps double check the diameter. RE: Rust pitting on flywheel - Charles P - 21-03-2019 Given that the flywheel is both cheap and easy to replace with a better one at this stage ( and a total bloody pain to replace if the surface causes issues) I can see no logic for sticking with this pitted one. Charles RE: Rust pitting on flywheel - PhilM - 22-03-2019 Charles, I can't fault your logic, fortunately I'm in no hurry to resolve the issue of the flywheel as I'm in the early stages of my restoration, it'll be quite a while before engine / clutch go back together so meanwhile I'll keep my eyes open for a suitable replacement. Many thanks for your input. ..... Phil. |
