Brooklands inlet manifold - Printable Version
+--- Thread: Brooklands inlet manifold (/showthread.php?tid=2512)
Pages: 1 2
RE: Brooklands inlet manifold - Colin Ayre - 15-03-2019
If you look at the “hells confetti” website which is primarily for the front wheel drive Alvis and scroll down to accessories and select Solex Carburettors a full set of handbooks and data is available.
Colin
RE: Brooklands inlet manifold - Bill Sheehan - 16-03-2019
Looked through about 6 pages of listing on the hell's site, couldn't find it.  Cancelled, then typed up "Solex MOV" on Google Search, found the complete book which you can download as I did.    Suggest may be easier?   Good Luck, Cheers,  Bill
RE: Brooklands inlet manifold - Marcus Ling - 17-03-2019
Thanks Tom,
I dint know that John has those. I will be in the UK in August and was planning to go and see John to get some other bits so will take a good look at it. Shouldn't take up too much room in my suitcase. The last time we came, the kids came home with a crankshaft each in their bags.
Marcus
Thanks Terry,
I will go and see John when I'm over in August.
Marcus
