Nippy head gasket - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Nippy head gasket (/showthread.php?tid=2458) Pages:
1
2
RE: Nippy head gasket - Paul N-M - 05-03-2019 Did this for an overbored block with aluminium head. The nip is made by the s/steel 'ring' which seems to work well. Some initial water escape from the manifold side which seems to have subsided. Head torqued to 20 lb ft only still using 5/16ths studs. No heat treatment. Paul N-M RE: Nippy head gasket - Zetomagneto - 05-03-2019 Nice work Paul RE: Nippy head gasket - Scarlet O'Hara - 05-03-2019 Thats really excellent, far better than my man shed effort. I did think about the possibility of making the water passage holes in the gasket slightly bigger and fitting some viton or PTFE "O" rings in to seal the the head gasket. Anybody tried that or something similar yet? Would depend on the condition of the block and head around the water passages. RE: Nippy head gasket - Chris KC - 05-03-2019 Not that exactly Scarlet but I did attempt to address slowly expanding water passages in the head by boring them oversize and loctiting in inserts to bring them back to size. Only done 1000 miles since but it hasn't spat them out yet. The head did needed facing flat afterwards. RE: Nippy head gasket - Colin Reed - 05-03-2019 Hi All Congratulations to all the gasket makers What Thickness copper is being used on these Heads Normally copper Head gaskets will be varied in thickness depending on Tuning requirements (ie) lower or higher Compression Cheers Colin NZ RE: Nippy head gasket - Bruce Nicholls - 05-03-2019 Really impressed by the gasket makers. I did once make a pair of copper gaskets for a 2 stroke 2 cylinder marine engine for a boat I had. I cut these out with a coping saw and drilled the stud holes by clamping the 2 heads together and using the stud holes as guides. They were annealed with a blowtorch and cleaned up with a scotch pad. They were very successful and gave many years of good service. No where near the standard shown here though! RE: Nippy head gasket - Paul N-M - 07-03-2019 Hi Colin, Just picked up your question. 0.5mm copper sheet. Paul RE: Nippy head gasket - Colin Reed - 07-03-2019 THANKS PAUL Colin NZ RE: Nippy head gasket - Bob Culver - 07-03-2019 I am always surprised that solid gaskets without narrow raised borders work. With the various large temperature gradients it is difficult to imagine surfaces remaining flat. To remedy corroded holes, O rings seem a good idea; one problem is that any significant gas pressure leakage is in the direction opposite that O rings work. Where there is room, fibre rings probably just as effective. but either way the machining is much the same as involved as for a brass insert. Has anyone had experience with lapped heads without gasket? |
