Body to chassis spacers? - Printable Version
+--- Thread: Body to chassis spacers? (/showthread.php?tid=239)
Pages: 1 2
RE: Body to chassis spacers? - Shuttle - 15-09-2017
(15-09-2017, 07:46 PM)Duncan Grimmond Wrote: I have used neoprene foam self adhesive strip stuck to the chassis and it seems to reject water ingress and allows removal.
An expert in plastics I know, suggests a 'closed cell' material would be efficient.
Closed cell, means it doesn't absorb water.
RE: Body to chassis spacers? - Geoff Halstead - 17-09-2017
Andrew,
Mine did have packing pieces and I may have taken a photo/s of it/them, or added a description to my thread on the previous Forum, just don't remember.
Responses so far tally with what I found, especially the rust pits (dongas) under the felt that I found, as shown in one of the photos, so won't be using untreated felt again if I do that is, as closes cell sponge looks a good alternative.
To say I'm green looking at the photo of your body, car that is, makes me sigh as things are taking forever notwithstanding my foot.
Geoff - Ready to do the Tilter/Rotisserie video at last
RE: Body to chassis spacers? - andrew34ruby - 17-09-2017
Geoff, my rebuild is further on but I started this project 30 years ago. You might still beat me.
A big thanks to all that have responded re the packing pieces. I now have a better understanding of what's needed.
RE: Body to chassis spacers? - davidheywood - 17-09-2017
Suppliers of parts for rebuilding a Citroen 2cv sell rolls of 'closed cell' foam strip to go between chassis and body. A £10 roll is said to be enough for a 're-chassis' job. And some citroenistes cut strips from a backpacker's foam bedding roll, the kind you tie to your rucksack when going to festivals. It is definitely closed cell, but I do not know about the thickness. David
RE: Body to chassis spacers? - JonE - 17-09-2017
I bought an ebay roll of solid rubber 3 or 4mm thick, about chassis rail width, with self adhesive strip one side to allow for easy positioning.
Not expensive.
RE: Body to chassis spacers? - andrew34ruby - 25-09-2017
Thanks for all the ideas. The job is now done and the body firmly bolted to the chassis. Instead of Denso tape I used thin strips of rubber, and for the ends of the outrigger/crossmembers I cut squares of polyethylene from the edge of a kitchen chopping board. If seemed just the right thickness and was always too big. Trimmed down neatly it is now back in service in the kitchen.
RE: Body to chassis spacers? - Shuttle - 25-09-2017
[quote pid='1956' dateline='1506357516']
[/quote]
Has she noticed the missing chunks?
