Brookland style mufflers - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Brookland style mufflers (/showthread.php?tid=2336) Pages:
1
2
RE: Brookland style mufflers - jansens - 06-02-2019 Thanks Bill, I'll have a hunt about the AustinHarris site at their photos. Simon RE: Brookland style mufflers - Chris KC - 06-02-2019 That's interesting, must admit I'm still wondering how the domed ones were made! Though they do look nice. p.s. did your DVD's arrive Bill? RE: Brookland style mufflers - squeak - 06-02-2019 (06-02-2019, 10:00 AM)Chris KC Wrote: That's interesting, must admit I'm still wondering how the domed ones were made! Though they do look nice. I've always believed they first bent a full tube, laid it flat on the bench and sliced it lengthwise on both sides. Throw away the bottom half. Repeat the process for another example. You now have 2 sections which when married to 2 pieces of flat plate, will provide the body of the muffler. At least that's how I would do it. cheers Russell RE: Brookland style mufflers - Dave Wortley - 06-02-2019 I made mine to Chris Gould's drawing along with the authentic tapered tube exhaust manifold. The curved silencer ends were made up in 3 or so separate bits per end. I tried it on the car and found it very noisy and not pleasant to drive around even with the correct bore and length tailpipe with fishtail. I cut the back off thesilencer Bl**dy phone! I cut the back off and made a tapered pipe with lots of holes drilled in it then stainless mesh and stuffed the can with mineral wool insualation. Much nicer sound. RE: Brookland style mufflers - Chris KC - 06-02-2019 (06-02-2019, 01:25 PM)squeak Wrote:Sounds rather labour-intensive Russell. I'd have thought they'd have made a stamped/ pressed part and welded together but if so I don't know where the joins were.(06-02-2019, 10:00 AM)Chris KC Wrote: That's interesting, must admit I'm still wondering how the domed ones were made! Though they do look nice. RE: Brookland style mufflers - Derek Sheldon - 06-02-2019 Diagrams from C Guold. Make a wooden former and cut and shut mild steel to get the correct profile. Make two halves and join together. RE: Brookland style mufflers - Bill Sheehan - 07-02-2019 (06-02-2019, 06:04 PM)Derek Sheldon Wrote: Dis grams from C Guold. Make a wooden former and cut and shut mild steel to gitChris KD - yes, arrived yesterday, Thank you. Wrote you a Thank You letter but haven't posted it yet! To Others - I made several Brooklands silencers over the years, copying what I thought was an original one. It had flat ends. I recall with chagrin one made for a friend and he decided to make it look "pretty" and polished the steel. To assist this he ground down the welds on the joins. A few months later the muffler disintegrated with a roar whilst he was driving his Ulster! Turned out he'd been a little too exuberant with his grinding wheel and everything was paper thin. Something to be careful about. Cheers, Bill in Oz RE: Brookland style mufflers - Mark Atkinson - 08-02-2019 Hello Simon, I am just making a Silencer for Slippery Anne based on the one used for the car between 1925 - 28, which was the earlier very 'rounded' pattern (see the attached period pictures). The overall dimensions are the same as quoted by Chris, who may be interested In the first picture, as it almost looks as if the cones are welded onto the centre section of the silencer. I am forming it from 1mm steel, which I have to say is hard going after the malleability of aluminium! It is worth the effort though, as it looks so much more interesting than the flat ended ones. Kind regards, Mark. DSC_0810_2.jpeg (Size: 41.25 KB / Downloads: 142) RE: Brookland style mufflers - Chris KC - 08-02-2019 Impressed! RE: Brookland style mufflers - Derek Sheldon - 08-02-2019 Looking good |
