auto vs. manual ignition setting? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: auto vs. manual ignition setting? (/showthread.php?tid=1832) Pages:
1
2
RE: auto vs. manual ignition setting? - Colin Wilks - 04-10-2018 (04-10-2018, 05:54 PM)David.H Wrote:Yes.(04-10-2018, 09:04 AM)Colin Wilks Wrote: A very useful ready reckoner a forum member told me about is one tooth = 4.5°.Anti clockwise viewed from above?..... RE: auto vs. manual ignition setting? - Bob Culver - 04-10-2018 On my RP the advance lever moves the distributor about 1/2 inch at 2 inch radius, indicating near 30 deg of crank degrees. The rod may not be original length; a short rod can give a reduced and very non linear range. Also spring loaded to eliminate back lash. Even for hand cranking retard beyond TDC is not necessary. It would seem far preferable to stick with full advance as the reference, as per handbook instructions. If tinkering it may be of interest to determine just where TDC is on the lever in individual cars. RE: auto vs. manual ignition setting? - David.H - 04-10-2018 (04-10-2018, 06:56 PM)Colin Wilks Wrote:(04-10-2018, 05:54 PM)David.H Wrote:Yes.(04-10-2018, 09:04 AM)Colin Wilks Wrote: A very useful ready reckoner a forum member told me about is one tooth = 4.5°.Anti clockwise viewed from above?..... Thanks! D RE: auto vs. manual ignition setting? - Steve Bryant - 05-10-2018 I'm not sure how successful this will be, but I modified my flywheel with timing marks in 5 degree increments so that timing can be assessed more easily against a pointer which will be attached to the crankcase. Cheers, Stephen RE: auto vs. manual ignition setting? - jansens - 05-10-2018 Painted clutch springs! I thought I was pedantic getting things looking nice Simon RE: auto vs. manual ignition setting? - Steve Bryant - 05-10-2018 It's away to differentiate the clutch springs from the valve springs which I don't paint....plus it looks nice ! Stephen |
