Weighing rods Etc - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Weighing rods Etc (/showthread.php?tid=1493) Pages:
1
2
RE: Weighing rods Etc - AustinWood - 26-07-2018 Not sure how you would use a micrometer when balancing rods. RE: Weighing rods Etc - Speedex750 - 26-07-2018 Maybe not with micrometers but the point being made is the difficulty and care needed when measuring anything down to small figures - a few grams in this case for balancing. Dave RE: Weighing rods Etc - Ian Williams - 26-07-2018 If you are having trouble with a micrometer's accuracy I would suggest you are being overly pedantic! Balancing components to within a gram is worthwhile in my experience, even if you had a slightly bigger tolerance it is a dam sight better than +/-10g found in some rod piston sets. |
