Holden body - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Holden body (/showthread.php?tid=1194) |
RE: Holden body - 153624 - 26-05-2018 (26-05-2018, 03:43 AM)Tony Press Wrote:(26-05-2018, 01:02 AM)Bill Sheehan Wrote:(25-05-2018, 03:49 AM)Tony Press Wrote:(24-05-2018, 12:03 PM)153624 Wrote: Sorry for the delay, hopefully this is useful. Ive been told it is an early holden body car built in october 1927. From what I can gather my vehicle is most likely a late 1927 chummy made by Melbourne motor body builders, I believe the first owner was a lady in carlton and that it originally had a yellow stripe where the swage line would be. It currently has lucas king of the road headlights which I dont know if they are original, however they have always been mounted on the guards. Does anyone have any information about Melbourne body builders that could be used to support this theory? One other thing that might be worth mentioning, My vehicle has an aluminium scuttle with a raised join to the steel rear section at the bottom of the doors. Thanks, Luke RE: Holden body - steve davidson - 28-05-2018 (26-05-2018, 11:35 AM)153624 Wrote:Hi Luke,(26-05-2018, 03:43 AM)Tony Press Wrote:(26-05-2018, 01:02 AM)Bill Sheehan Wrote:(25-05-2018, 03:49 AM)Tony Press Wrote:(24-05-2018, 12:03 PM)153624 Wrote: Sorry for the delay, hopefully this is useful. Ive been told it is an early holden body car built in october 1927. Attached are pages 132 and 134 of the Austin Seven Source book by Bryan Purves RE: Holden body - Bill Sheehan - 29-05-2018 (28-05-2018, 10:48 AM)steve davidson Wrote:(26-05-2018, 11:35 AM)153624 Wrote:Hi Luke,(26-05-2018, 03:43 AM)Tony Press Wrote:(26-05-2018, 01:02 AM)Bill Sheehan Wrote:(25-05-2018, 03:49 AM)Tony Press Wrote: Hi Luke, RE: Holden body - Tony Press - 29-05-2018 Try again Bill. Cheers, Tony. RE: Holden body - dwhitelephant - 29-05-2018 I bought recently from Adelaide a car identical to the car in question with respect to the bodywork/ windscreen etc, it also has an aluminium scuttle identical to an Austin manufactured one and this also turns to a steel rear section behind the doors with no swage either. It was a barn find last used in 1956 still with a South Australia tax disc in the window, its car number was registered as the engine number M60171 making it around early 1928 assuming the original engine intact as everything else was, interestingly a scuttle vent exists in front of the windscreen. As there are no chassis stampings on cars of this time in question they must have been registered by engine no. The hood is not as Holden cars a' sort of pram hood' but a standard Austin works style of the time. The lucas chummy scuttle lamps are fitted as standard at the windscreen on those awful brass windscreen supports. hope this helps RE: Holden body - Bill Sheehan - 30-05-2018 (29-05-2018, 10:05 PM)dwhitelephant Wrote: I bought recently from Adelaide a car identical to the car in question with respect to the bodywork/ windscreen etc, it also has an aluminium scuttle identical to an Austin manufactured one and this also turns to a steel rear section behind the doors with no swage either. It was a barn find last used in 1956 still with a South Australia tax disc in the window, its car number was registered as the engine number M60171 making it around early 1928 assuming the original engine intact as everything else was, interestingly a scuttle vent exists in front of the windscreen. As there are no chassis stampings on cars of this time in question they must have been registered by engine no. The hood is not as Holden cars a' sort of pram hood' but a standard Austin works style of the time. The lucas chummy scuttle lamps are fitted as standard at the windscreen on those awful brass windscreen supports. hope this helps dwe - we have evidence of at least a dozen chassis on 1929 Sevens that don't have the chassis number stamped, even though many English owners don't believe us. However, I've never heard before of a 1928 chassis or any other year except 1929 not being stamped and stencilled. Are you sure you are looking in the right place with gunk & paint removed? Further to other posts above, I apologise for forgetting to bring from home a list of other body suppliers in the period, which indicates that perhaps Holden-making isn't always a certainty. Sounds like your car is a great find - enjoy. Good Luck, Cheers, Bill RE: Holden body - Tony Press - 30-05-2018 (26-05-2018, 11:35 AM)153624 Wrote: [quote pid='10733' dateline='1527302638'] [/quote] Luke, You haven't mentioned the engine number or chassis number of your Austin Seven, which will help date it. The engine may not be original but if it is it would be within a few hundred of the chassis number. For a 1927 car they should be roughly between 30,000 and 50,000. As well as Holden and Company and Melbourne Motor Body Builders, other Australian Austin Seven body builders include J W George Melbourne , William Green Sydney, New South Wales Motors, James Flood Melbourne, A Robinson and Company Sydney, Properts Motor Body Company Sydney, Latrobe Motors Melbourne (who I believe had others build the bodies for them to sell as Latrobes). Below is the later Holden ID plate fitted to cars in 1929-1930 csm_Holden_badge_2_a82b44a499[1].jpg (Size: 19.45 KB / Downloads: 224) My knowledge of Melbourne Motor Body Builders- Tarrant Motors started selling cars in Victoria during the first decade 1900’s with several operating subsidiaries including Smith’s coach building business in Queensbridge Street, South Melbourne in 1903. Four years later the motor body department moved to larger premises in Exhibition Street, Melbourne and adopted the name “Melbourne Motor Body Works”. In 1909 larger premises in Lygon Street were acquired when contracts were obtained from Fords. There followed further expansion with a new factory at 149 Lonsdale Street Melbourne during the First World War. In 1925 Ford built their own plant at Geelong and ‘Melbourne Motor Body Works’ returned to the manufacture of bodies for a range of British and American car chassis. In 1929, the trade depression hit hard and a workforce of 400 fell to just 40. I assume that around this is time they combined with Holdens . Apparently in February 1930 the company changed its name to Ruskin Motor Bodies Ltd. of Dudley Street, West Melbourne. As “Ruskin Motor Bodies Pty Ltd,” bodies were made on chassis for Morris Motors Ltd. and Hudson Terraplane, these two accounting for much of the firm’s production up to 1939. Cheers, Tony. RE: Holden body - 153624 - 30-05-2018 (30-05-2018, 05:51 AM)Tony Press Wrote:(26-05-2018, 11:35 AM)153624 Wrote: [quote pid='10733' dateline='1527302638'] Luke, You haven't mentioned the engine number or chassis number of your Austin Seven, which will help date it. The engine may not be original but if it is it would be within a few hundred of the chassis number. For a 1927 car they should be roughly between 30,000 and 50,000. As well as Holden and Company and Melbourne Motor Body Builders, other Australian Austin Seven body builders include J W George Melbourne , William Green Sydney, New South Wales Motors, James Flood Melbourne, A Robinson and Company Sydney, Properts Motor Body Company Sydney, Latrobe Motors Melbourne (who I believe had others build the bodies for them to sell as Latrobes). Below is the later Holden ID plate fitted to cars in 1929-1930 My knowledge of Melbourne Motor Body Builders- Tarrant Motors started selling cars in Victoria during the first decade 1900’s with several operating subsidiaries including Smith’s coach building business in Queensbridge Street, South Melbourne in 1903. Four years later the motor body department moved to larger premises in Exhibition Street, Melbourne and adopted the name “Melbourne Motor Body Works”. In 1909 larger premises in Lygon Street were acquired when contracts were obtained from Fords. There followed further expansion with a new factory at 149 Lonsdale Street Melbourne during the First World War. In 1925 Ford built their own plant at Geelong and ‘Melbourne Motor Body Works’ returned to the manufacture of bodies for a range of British and American car chassis. In 1929, the trade depression hit hard and a workforce of 400 fell to just 40. I assume that around this is time they combined with Holdens . Apparently in February 1930 the company changed its name to Ruskin Motor Bodies Ltd. of Dudley Street, West Melbourne. As “Ruskin Motor Bodies Pty Ltd,” bodies were made on chassis for Morris Motors Ltd. and Hudson Terraplane, these two accounting for much of the firm’s production up to 1939. Cheers, Tony. [/quote] Being an ex Bob Booth car it has had a few different engines in it, originally it had a magneto engine which is long gone. In 1977 engine number M66422 was replaced with engine number M217175. When Bob purchased the car he also bought the original engine separate, which he reinstalled. The car now has a pressure fed distributor engine with a 1937 high compression head. Apparently the chassis has never been removed from the body and it has the original front axel and rear differential, I dont know what the chassis number is, was it stamped into the chassis somewhere? RE: Holden body - Bill Sheehan - 31-05-2018 Further to above re possible Body builders (and not necessarily Holden) in the period mentioned. Try Richards, Green, Steenbohm, Propert, Agate, Sweeney, George, Dan White, plus another near the cnr of Carlisle & Brighton Rds, St.Kilda, whose name I've temporarily forgotten. Although a few of them were based in Sydney, Austin Distributors in Melbourne dealt with all of them including Holden. (Apart from Green who also made a coupe, the above list does not include the specialist builders of Sports bodies). Take your pick. Cheers, Bill And Tony, I was told by an ex employee of Ruskin Motors that he felt that just as many bodies were made for Austin as for Morris - in fact he claimed they produced one body that could be adapted to either chassis! - but guessed more for Austin, that's why he felt Austin bought them out and assembled their own products from then on. Cheers, Bill RE: Holden body - Tony Press - 31-05-2018 "Apparently the chassis has never been removed from the body and it has the original front axel and rear differential, I dont know what the chassis number is, was it stamped into the chassis somewhere? " Luke, Have a look at - http://a7ca.org/downloads/QuoteThisNumber.pdf which shows where all the various car numbers are found. Tony. |
