Top Tips - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Top Tips (/showthread.php?tid=1159) |
RE: Top Tips - Ray White - 06-05-2018 Make sure the rear axle tapers are tight. I suspect there are many A7s rattling around on their key ways with a view to a broken half shaft. RE: Top Tips - Colin Morgan - 07-05-2018 If you come across woodworm and treat it, put a pencil circle round each hole - then you can see if there is any fresh activity next time you look. The blighters can continue to emerge for some years - in the summer - and if two get together and lay eggs, then there could be a lot more trouble... Colin RE: Top Tips - Tony Press - 07-05-2018 (06-05-2018, 07:32 PM)Dave Wortley Wrote: True Ian they are quite weak. I have my own torque wrench ie. losing arm strength through getting old and weedy. And using the standard Austin Seven Wheel Brace should limit the torque! Cheers, Tony. RE: Top Tips - Mike Costigan - 08-05-2018 Newcomers to an Austin Seven can be alarmed at the lack of pressure shown on the oil gauge! As a general rule-of-thumb, once the engine is fully warmed through - and that can easily be five to ten miles running - approximately 1psi per ten mph is about right (on a 2-bearing engine, perhaps slightly less, on a three-bearing engine maybe a bit more). RE: Top Tips - Colin Morgan - 08-05-2018 Yes, it can be alarming the first time stopped at traffic lights once the engine has thoroughly warmed up - with almost no pressure showing. This is in stark contrast to start-up, when the pressure shoots off-scale and should stay there a while. Colin RE: Top Tips - Robert Leigh - 08-05-2018 (07-05-2018, 04:34 PM)Colin Morgan Wrote: If you come across woodworm and treat it, put a pencil circle round each hole - then you can see if there is any fresh activity next time you look. The blighters can continue to emerge for some years - in the summer - and if two get together and lay eggs, then there could be a lot more trouble...I like to plug old woodworm holes with boot polish; then any new holes show very easily. Robert Leigh RE: Top Tips - Colin Morgan - 08-05-2018 Do others use a standard wooden clothes peg to hold out the choke? (This tip came from Jim Young of the PWA7C even before I had put my car on the road.) The spring is a bit strong, so I have always use two - they look older than the car after years of use. Not sure if they are available any more in this time of plastic - do any of the cherished suppliers carry them? RE: Top Tips - Viteran - 08-05-2018 I thought everyone did, I assumed the peg was part of the original kit ! RE: Top Tips - Colin Wilks - 08-05-2018 (08-05-2018, 04:55 PM)Colin Morgan Wrote: Do others use a standard wooden clothes peg to hold out the choke? (This tip came from Jim Young of the PWA7C even before I had put my car on the road.) The spring is a bit strong, so I have always use two - they look older than the car after years of use. Not sure if they are available any more in this time of plastic - do any of the cherished suppliers carry them? Not sure about the choke as I've only managed to get my car round the block so far, but I can confirm a standard wooden clothes peg is ideal for holding the cam followers clear when removing or installing the camshaft (with thanks to Ian Bancroft for the tip). RE: Top Tips - Austin Carr - 08-05-2018 (08-05-2018, 04:55 PM)Colin Morgan Wrote: Not sure if they are available any more in this time of plastic - do any of the cherished suppliers carry them? I don't about cherished suppliers but wooden ones are available at Tesco and other supermarkets:- https://www.tesco.com/groceries/en-GB/products/273772520 |
