Three bearing engine - centre bearing - Printable Version
+--- Thread: Three bearing engine - centre bearing (/showthread.php?tid=1128)
Pages: 1 2
RE: Three bearing engine - centre bearing - DavidL - 01-05-2018
Reminds me of this article:
http://myweb.tiscali.co.uk/speedex/index_files/Page2152.htm
RE: Three bearing engine - centre bearing - Derek Sheldon - 01-05-2018
My advice would be, ditch th three bearing crank,  buy a Phoenix crank and get the crankcase converted to two bearing.
Then again some people have run three bearing for thousands and thousands of miles
RE: Three bearing engine - centre bearing - john williams - 01-05-2018
(01-05-2018, 07:51 AM)Stephen Barker Wrote: Have put some shims between the centre main clamp bolts and torqued the bearing to 50lbs and the crankshaft rotates reasonably free now, will put the block on and see what difference that makes.
Stephen, putting shims between the centre bearing caps is not a solution. You need to read the article written by the late Jem Marsh of Speedex fame, for the explanation of the cause and remedy for centre main distortion of three bearing crankcases. If you cannot find the Jem Marsh explanation, send me an email jonniejumble@googlemail.com, and I will send you an article I produced for SWA7C, based on Jem's original work. John
