All Alloy Cup progress - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: All Alloy Cup progress (/showthread.php?tid=1822) |
RE: AllAlloyCup progress - AllAlloyCup - 03-02-2019 They say that the lightest, fastest Supermaribe Spitfires Were those that had no paint, just bare polished aluminium And flush rivets. To gain an extra 1mph top speed I have followed this design feature to its logical conclusion on my AllAlloyCup. I found these neat little stainless 4mm Domed coach bolts on EBay and they will surely help with the streamlining? Handy for those fixings inside the bonnet compartment. Regards Bill G RE: AllAlloyCup progress - AllAlloyCup - 05-02-2019 Just stripped and rebuilt the OM SU and will fit the AN needle as advised plus have sorted out A neat petrol filter. Waiting on some pipe bits to To finish off. I’ve an original tank , but unsure whether to coat the inside, Or rumble some ball bearings in it, or let sleeping dogs lie? I changed the filler cap to a screw on one. Any suggestions about the inside of the tank. Plus sent the rad shell off to the platers, so better start Saving up! Regards Bill G RE: AllAlloyCup progress - Hedd_Jones - 05-02-2019 Are you aluminium plating the cowl Bill?. That would look good. One fabricated in Ali would be even sexier. RE: AllAlloyCup progress - AllAlloyCup - 05-02-2019 Hi Hedd By the cowl, do you mean the fabric cover that original GE Cups used? I am planning to do machine turning on the bulkhead which is an extra bit of bling I’ve been contemplating as well as replacing the fabric cowl With an easily shaped alloy part to replace it? I have a shrinker stretcher and quite a lot of alloy sheet left over so I can probably manage most of it myself. Would need to see how easy it would be to remove In case I needed to do work under it though. Will make a cardboard one, like the dozens of patterns I’ve made since the start!!! Regards Bill G Perhaps by cowl you meant the rad shell? No it will be nickelled as it’s a steel chummy one. At some stage I may paint the car... but not this year Regards Bill G RE: AllAlloyCup progress - AllAlloyCup - 10-02-2019 Here’s some photos of the throttle linkage and SU carb pipe work and filter I’ve temporarily fitted. Note the 3 x small loose collars on the throttle cross shaft to locate everything, two between the mounting points and one to locate the slow running lever against the stepped boss of the accelerator pedal. I’ll either pin these or drill and tap them for grub screws. The carb is in approx the correct position, I used 2 ft of piping and put a coil in it to absorb some vibration that might set up between the engine and the bulkhead. I soldered the banjo and Union using my Creme Brûlée torch... Now trying to figure out the optimum length/ angle of the control rod linkage from SU butterfly shaft to the operating end of the throttle cross shaft and pick two control rod ends which work smoothly. I’ve got all the bits for the choke control too ( a pivot bracket, Ruby dash choke and some SS 2mm rod. But can’t fit those till the engine and bulkhead are finally fitted. One or two minor steering wheel things to attend to before refitting the column . All fiddly jobs but quite satisfying. Regards Bill G aka AllAlloyCup Sent from my iPhone RE: AllAlloyCup progress - Ruairidh Dunford - 10-02-2019 Bill, Have you considered fitting a pump? RE: AllAlloyCup progress - AllAlloyCup - 10-02-2019 Hi Ruaridh The level at the jet head is well below the bottom of the tank And numerous posts have said that this SU set up can work reliably As long as the tank has a fair level of fuel in it. This OM has a throat slightly less than 1” so I’m happy to try out this Arrangement with the AN needle. I had a daft thought that the other way to ensure a full fuel feed was to fit an Ulster type air pump? If need be an SU pump can be retrofitted. Has anyone tried this out on a Chummy with a non cooking engine. Eg standard valves and camshaft , but alloy HC head, lightweight pistons and steel crank, I’m not planning to do racing! If I can keep up with Jim H or Malcolm P I’ll be happy enough! Regards Bill G RE: AllAlloyCup progress - jansens - 10-02-2019 I have been looking at how to do my throttle linkage too and I think I can do a simple linkage similar to yours (am using the same throttle linkage across the firewall but an DD SU) as long as I get the lengths right. You can buy the ball linkages of various lengths from Burlen new still. They weren't hugely expensive either. I was going to use one of the little clamp on brass arms on the throttle spindle on the carb maybe. Simon RE: AllAlloyCup progress - AllAlloyCup - 10-02-2019 Hi Simon I have a brass cast lever on the butterfly spindle and I’ve bent the end of throttle cross shaft so that it’s roughly under the end of the brass lever. There’s not a huge amount of travel on the throttle pedal and I just need to make sure that flooring the pedal approximates to maximum opening of the butterfly, so probably will need to Sit the engine in the chassis, fit the floor boards and bulkhead and then Cut a suitable short throttle control rods with nice movement at each end with No stiffness and effective return spring( already bought) Will post pics when I’ve figured it out!! Pls post photos if yours is set up. Regards Bill G RE: AllAlloyCup progress - Ruairidh Dunford - 10-02-2019 This was an effective temporary (and cheap) solution from a very similar set up that may help you as well. https://www.amazon.co.uk/dp/B07CYT7MDQ/ref=asc_df_B07CYT7MDQ58443772/?tag=googshopuk-21&creative=22146&creativeASIN=B07CYT7MDQ&linkCode=df0&hvadid=310868547772&hvpos=1o1&hvnetw=g&hvrand=3292929572649365502&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1006886&hvtargid=pla-562112152270 |
