Faces for Austin Seven Instruments and Gauges (Page 2)
Hint: Having trouble getting the "save as...."  dialog box to save these download files to your local computer? Getting a new frame with junk in it instead? This can be a problem with some Netscape versions.... Just use the 'Back' button to get back to this screen and try holding the 'Shift' key down when you click the desired link. Win95/98/NT/me/2000/XP users can also right mouse button click on the selected link and use the "Save Link As...."   (or "Save Target As...." in IE 4 or greater browsers) option to achieve the same result.
Speedo Dial PA
Artwork by Bruce White
Download versions available on this site are:
CorelDraw Version 10 format (34k)
CorelDraw Version 3 format (44k)
High Resolution JPG format (154k)
Speedo Dial PN
CorelDraw Version 10 format (39k)
CorelDraw Version 3 format (52k)
High Resolution JPG format (141k)
Speedo Smith's Wheel Type
CorelDraw Version 10 format (22k)
CorelDraw Version 3 format (23k)
High Resolution JPG format (45k)
Speedo Smith's Disc
CorelDraw Version 10 format (42k)
CorelDraw Version 3 format (46k)
High Resolution JPG format (122k)
Smith's Logo (2 times original)
CorelDraw Version 10 format (21k)
CorelDraw Version 3 format (20k)
High Resolution JPG format (44k)
1930's Exide Battery Label (170mm x 140mm)
Make your new battery look old.....
CorelDraw Version 10 format (27k)
CorelDraw Version 3 format (27k)
High Resolution JPG format (505k This will be slow over a modem connection!)
