Austin Seven Breakdown Spares and Tools List
Source: The Austin Sevens Clubs' Association Breakdown Register 1995
SPARES TOOLS
Insulation tape
Gaskets & Goo
Super Epoxy Resin
Length of Wire
Distributor or Mag
Coil. Gear Lever
Half Shaft
Bearings
Sparking Plugs
Core Plugs
Sump plug & Others
Set of Keys (Woodruff)
Set of Bulbs
Fuses
Wheel nut (on Spare)
Fan Belt
Dynamo & Brushes
Petrol Pump Repair Kit
Brake Cables I.F./I.B.
Conrod check size
Brake shoe spring
Valve Spring Valve 2
Hose & Clip
Spare Petrol Pipe or Connector
Various Studs. Bolts, Nuts, Splitpins.
Fibre Washers etc.
Piston (check size)
Tyre Valves
Crank Shaft
C/W Pinion
King Pin,
Oil, Water
1/2 Gallon Petrol
Change for phone
Screwdrivers (2)
Jack
Wheelbrace
Large Adjustable Spanner
Socket Set
Pliers
Mole Grips
Plug Spanner
Set Spanners
Hub Puller
Fly Wheel Puller
Syringe for axle oil or Plastic
Container with Pipe
Grease Gun
Wire Brush
Emery Paper
Feeler Gauge
Hammer
Junior Hacksaw
Knife. Blade. Scissors
Jet Wire
Foot pump
Tow rope
Valve Clamp
Piston Ring Clamps
Clean Rag
Torch
Small set Taps and Dies
3 sizes Whit. 3 sizes BSF
Puncture Outfit
Tyre levers
Wiper Blade
Length H/T Lead
Set of Points
The source for the above list is The Austin Sevens Clubs' Association Breakdown Register 1995. The only thing I would add is that most drivers now should carry a mobile phone with a list of emergency telephone numbers.......
