Austin Seven Magneto Information
Large File alert:
Be prepared for a download that will take several minutes for 56k modem users! ALL Files contain the SAME information - choose the format that suits you.
Magneto
Information (Word file - .doc 710k)
Magneto Information
(Standard Web Html file - .Htm 642k)
To view PDF files you require an Adobe PDF viewer on your system. Most users will have this software installed. If you require this software, a link to the Adobe site is provided at the bottom of this page.
Hint: Having trouble getting the "save as...." dialog box to save the Word File above to your local computer? Getting a new frame with junk in it instead? This can be a problem with some Netscape versions.... Just use the 'Back' button to get back to this screen and try holding the 'Shift' key down when you click the desired link. Win95/98/NT/me/2000/XP users can also right mouse button click on the selected link and use the "Save Link As...." (or "Save Target As...." in IE 4 or greater browsers) option to achieve the same result.
