Car type:
I've got some scale drawings of the Nippy rad from Stewart Brown. I don't really want to post them on here as they have copyright stickers on them, but am sure he wont mind me sending on to someone who is trying to convert or check something. Send me an email address by pm...
(If you tune in here Stewart, let me know if I can upload them to Nippy archive if I take the personal details off! )
Hello Chris,
on my Ulster reproduction I used a RN type radiator with the neck at the front.
Mr Bryant of Tunbridge Wells removed the original neck and soldered an L shaped patch over the hole . Then he soldered a new neck in the correct position and recored it with a A type film to the correct height.
If you have a new neck turned up to the correct shape then most competent radiator companies should be able to to do the job for you.
There is a company in Australia who still make the dimpled top tank if you choose to replace the existing one
Hope this is of help,
Robert
be quick I think I may have had the second last one recently, they come blank with no hole or filler neck and the underside plate is separate with likewise no hole. cheers Russell
Getting away from the tank, in past discussions on the radiator shell I, and I think others, said that the Ulster had the second type of mounting bracket. This shell has the two bolts mounted through the front face. By the time the 65 and Nippy appeared, they were mounted on a third type of bracket resulting in no bolt-holes in the front face. But some time ago Ruairidh reminded me of the photo above and perhaps there were some Ulsters fitted with the third type - although my search through photos of standard cars as well as Ulsters only show the earlier mounting. This plus the honey-comb core in the photo makes that Ulster curious - or was it correct & perhaps similar in others? Cheers, Bill in Oz
